有请leslie兄 [复制链接]
查看: 4039|回复: 8
leslie兄你好,小弟最近进了对二手杰士KG4.2,怎末也找不到对他的相关资料,您对这对箱子了解吗,给介绍一下,多谢了
[upload=jpg]Upload/200541311543715605.jpg[/upload]
You have selected a Klipsch Classic product. The two-way KG Series KG 4.2 floorstanding loudspeaker was first introduced in 1992 and manufactured by Klipsch until 1994. While no longer in production, KG 4.2 model loudspeakers are still owned and listened to by Klipsch fans around the world as part of two-channel audio and home theater surround sound systems. To connect with other people who are passionate about audio and interested in Klipsch Classic products, visit one the several Klipsch Classic areas on our open forum bulletin board.
Specifications
FREQUENCY RESPONSE:
36Hz-20kHz±3dB
SENSITIVITY:
95dB @ 1watt/1meter
POWER HANDLING:
100 watts maximum continuous (500 watts peak)
NOMINAL IMPEDANCE:
8 ohms
ENCLOSURE TYPE:
Bass reflex via passive radiator
DRIVE COMPONENTS:
Two-way system using one 1" (2.54cm) phenolic dome compression driver tweeter with a 90°x60° Tractrix® Horn, one 10" (25.4cm) front-firing, ICG cone woofer and one 10" (25.4cm) front-firing, ICG cone passive radiator
TWEETER:
K-85-K 1" (2.54cm) Phenolic dome compression driver
HIGH FREQUENCY HORN:
HF CROSSOVER:
1600Hz
WOOFER:
K-1005-K 10" (25.4cm) ICG cone active / KD-101-K 10" (25.4cm) ICG cone passive
DIMENSIONS:
30.5" (77.5cm) x 13.5" (34.3cm) x 11.75" (29.8cm)
WEIGHT:
44 lbs. (20kg)
ENCLOSURE MATERIAL:
Medium density fiberboard construction (MDF)
FINISHES:
Walnut Oil, Oak, Oil, Oak Clear, Finished Black
BUILT FROM:
1992
BUILT TO:
1994
要几M?
是呀,几米进的?
这对喇叭素质怎末样,新的多少钱?
看评论说还不错哟。
谢谢leslie兄。
3000块不错啊, 我买喇叭的时候从来没碰见什么特价的东西。买的早不如买的巧。
不到3000元,库存货,外观有划痕,单元全新
GOOD CHOICE
羡慕,
