似乎大家认为B&W没有好货? [复制链接]
查看: 14031|回复: 40
最近突然很想试试signature 805,但是坛上那么多人猛批B&W,请各位对这个型号评价一下,另外请问什么功放比较对它的胃口呢
S805要求是150瓦吧? 新802D要求最好以500瓦功放推.
那个黄黄的东西要是灰色或黑色还差不多,为何是黄色呢!难看死了。非常不和谐哦。
Today, 01:21 AM    #1 (1)
Chelseaforever
Junior Member
Posts: 2   802D's just arrived
If you own a pair of N802's it's probably best if you don't read this.
I have had a pair of 802's for a year and couldn't resist the opportunity of auditioning the new 802D's when the opportunity arrived.
I was blown away. I couldn't believe the improvement on what was a very good speaker.
I ordered immediately and they arrived last night. Wow, out of the box they sound truly amazing. The bass is richer, fuller, tighter, better in every way. Although the lower end dynamic range is the same on paper it's tunefulness makes it seem far deeper. The midrange and treble blend seemlessly together. That slightly metallic extreme top end has been replaced by a sweet, transparent beautifully balanced sound. All colouration from the midrange has gone revealing detail never heard before.
I thought the original speaker was pretty special but this is just in another league. I took quite a big hit selling the 802's after just a year but the outlay is more than justified by the results. I just can't stop smilling as I listen.
For your info they are being driven by a Bryston 4BSST power amp, Naim CDS2/XPS, Naim NAC 52/Supercap.
这么丑样的,象没有脖子的企鹅。再有一个黄黄的大东西在冲着自己,自己家里要放这东西不可接受。
国内音乐传真CD机卖得不少,但是和NAIM,.LINN其他等英国厂比,它的声音是一种LIFELESS,无神无,生命的.
我用MARK LEVINSON的PROCEED HPA2,效果很好! B&W + MARK是最佳配置. 两者都中性,细致,贵气,全面,平衡又理性,,但是姻源就不要过于白亮,因为B&W高音很亮. 英国的CD/DVD机最好,如NAIM, LINN等.
谁说B&W800,700系列不好,说明他还没有玩到水平.
我对外观倒是无所谓,况且SIGNATURE的还是很不错
用CHORD CPM2600能推S805吗
