NAT Magma Single Ended Mono - Limited Edition [复制链接]
查看: 2283|回复: 0
NB啊....
-Technical Specification:
Type
Single Ended Class "A"
Power Output
160 Watts @ 4 & 8 ohms; 1 kHz
Frequency Response
10 Hz to 100 kHz; -3dB
Input impedance
100 kohms
Input Sensitivity
2.7 V RMS for full power output
Gain
22.50 dB at 8 ohm
Rise Time
5 microseconds
Noise
105 dB below rated output
Phase status Non inverting ( 0o )
Tube Complement 1x 6N1P-EV, 1 x 6N30P-DR , 1 x 450 TH
Power Requirement  110 VAC or 220 VAC @ 50 to 60 Hz, 450 VA
Dimensions 11.8" (300 mm) wide ´ 25.2" (640 mm) deep ´ 14.2" (360 mm) high
NET Weight approx. 88 lbs (40 kg) unpacked / per piece
TOTAL Weight approx. 110 lbs (50 kg) packed / per piece
-Design Features:
- Single Ended pure class A mono block power amplifier
- Eimac power industrial type direct heated triode - 450TH (N.O.S.)
- DC coupled all tube circuit (only output transformer without capacitors)
- CE comfortable
- 160 W of pure class A @4ohms or @8ohms
- low global feedback configuration with damping factor of 20
- high capacity in power supply resulting to over 500joules of  energy storage
- custom designed power transformer of 1000W encapsulated-low density
- custom designed output transformer of 1000W encapsulated- last generation
- full double stabilisation of high voltage for driver tubes
- 6N1P-EV & 6N30P-DR long life military grade tubes for driver purposes
- full automatic bias with automatic-adjust (no any adjustment).
- variable bias (two mode with 40W & 160W of output power)
- balanced DC power to supply filament of output tube
- balanced regulated DC power to supply filament for driver tubes
- both input and output WBT connectors
- input  wired  with pure 6N silver (99,9999% of silver purity)
- all aluminum modulated chassis with double 25mm thick front panel
最后编辑edisonwu 最后编辑于 2007-11-18 10:08:09
