常见CD  Player光头、DA、 IC对照表 [复制链接]
查看: 20764|回复: 35
ACOUSTIC RESEARCH CD-07 SAA7220
ACCUPHASE DP85 AD1853 NJM4580
ACCUPHASE DP90 PCM63
ADC CD 250XR PCM54
AKAI CD25/26/27/32/36 KSS210A
AKAI CD37 PCM67P KSS210A NJM4558
AKAI CD52 KSS210A
AKAI CD55 AD1856 KSS210A
AKAI CD57 PCM67PJ KSS210 CXD1167Q
AKAI CD62 BO38258J
AKAI CD650/70 KSS210A
AKAI CD69 PCM63 KSS210A
AKAI CD-A70 MB84053B KSS123A//BO367214J
AKAI CD-M839 PCM56
AKAI CD79 KSS210A
AKAI CD750 KSS210A
AKAI CD73/93 PCM56 KSS155A(884806401)
ALBA CD420 PCM54
ALCHEMIST NEXUS APD32A 2x TDA1549
AMC CD60 PCM1716
AMC CD8A MN6474 (Technics MASH)
ANTHEM CD1 PCM1702
ARCAM ALPHA 5 TDA1541 CDM9
ARCAM ALPHA 5 PLUS TDA7310 SAA7220P/B TDA1541A CDM9
ARCAM ALPHA 6 SM5864
ARCAM ALPHA 7 PCM1710
ARCAM ALPHA 7SE PCM1716
ARCAM ALPHA 8 SM5864AP
ARCAM ALPHA 9 dCS RingDAC
ARCAM CD72 PCM1716
ARCAM CD92 dCS RingDAC
ARCAM DELTA 70.2 TDA1541-S1 cdm4/31
ARCAM DELTA 70.3 LM627
ARCAM DELTA 270 PCM69
ARCAM DELTA BOX 5 PCM67
ARYE CX-7 PCM1738
ARYE D-1 PCM1704
AUDIO ALCHEMY ENGINE v3.0 AD1862
AUDIO ANALOGUE MAESTRO AD1855
AUDIO INNOVATIONS ALTO PCM1716
AUDIO NOTE CD-1 PCM1710
AUDIO NOTE CD-2 AD1865
AUDIO NOTE DAC-3 PCM63
AUDIO RESEARCH CD1 SAA7341
AUDIOLAB 8000 CD CS4329
AVI SC2000MC PCM63
BLAUPUNKT CP2650 PCM54
CAMBRIDGE AUDIO CD1 TDA1541
CAMBRIDGE AUDIO CD2 SAA7210 SAA7220P/A 4xTDA1541 CDM2
CAMBRIDGE AUDIO CD3 TDA1541A
CAMBRIDGE AUDIO CD4SE CS4327
CAMBRIDGE AUDIO CD6 TDA1305T
CAMBRIDGE AUDIO D500 CS4327
CARVER SD/A 450 MN6474
C.E.C. 530CD2 Y3015
C.E.C. 680CD LC7881
CONDOR CD950 YM3020
COPLAND CDA277 PCM63
COPLAND CDA288 PCM63-K
CROWN CD2111R LC7881
CYRUS CD7 PCM1716
CYRUS dAD1 TDA1311
CYRUS dAD3 TDA1305
CYRUS dAD3Q AD1861
CYRUS dAD7 AD1861
DENON DA-500 PCM1702
DENON DCD-315 NKS240A
DENON DCD-435 PCM1716E
DENON DCD-480 PCM61 NKS240A
DENON DCD-485 PCM1735
DENON DCD-500 PCM54 KSS123A
DENON DCD-520 KSS210A
DENON DCD-580 PCM67P NKS240A
DENON DCD-590 PCM61
DENON DCD-600 KSS152A
DENON DCD-610/20 KSS210A
DENON DCD-615/25 NKS240A
DENON DCD-635 PCM61P
DENON DCD-650F PCM1700P
DENON DCD-655 PCM1702
DENON DCD-660 KSS210A
DENON DCD-680 PCM69A
DENON DCD-685 PCM1702
DENON DCD-690 PCM61
DENON DCD-695 PCM61
DENON DCD-700 PCM54HP KSS123A
DENON DCD-715 NKS240A
DENON DCD-725 PCM61P-L
DENON DCD-735 PCM61
DENON DCD-755AR PCM1702
DENON DCD-800 PCM54 KSS152A
DENON DCD-810 KSS210A
DENON DCD-820 PCM56 KSS210A
DENON DCD-825 NKS240A
DENON DCD-860 KSS210A
DENON DCD-890 PCM61P NKS240A
DENON DCD-895 NKS240A
DENON DCD-900 KSS123A
DENON DCD-910 KSS210A
DENON DCD-920 PCM61 KSS210A
DENON DCD-980 PCM61P NKS240A
DENON DCD-1015 PCM61P NKS240A
DENON DCD-1000 KSS123A
DENON DCD-1100 PCM53JP-V KSS123A
DENON DCD-1290 NKS240A
DENON DCD-1300 KSS123A
DENON DCD-1400 PCM56
DENON DCD-1420 PCM54HP KSS210A
DENON DCD-1450AR PCM1702
DENON DCD-1500 PCM54HP-K KSS123A
DENON DCD-1500mk2 PCM56 KSS151A
DENON DCD-1520 PCM64 KSS151A
DENON DCD-1530 PCM61
DENON DCD-1550R PCM61
DENON DCD-1550AR PCM61P
DENON DCD-1560 PCM1701
DENON DCD-1650R PCM1702
DENON DCD-1700 KSS123A
DENON DCD-1800 PCM53
DENON DCD-2060G/80G NKS240A
DENON DCD-2560 4x AD1862
DENON DCD-2700 PCM1702J
DENON DCD-S10/3000 PCM1702J
DENON DCD-3300 PCM56P-K KSS123A
DENON DCD-3520 PCM64 KSS151A
DENON DCD-3560 PCM58P-K
DENON DCD-S1 PCM1702
DENON DCM-280 PCM1748
DENON RCD-100 PCM1710
DENON UCD-F10 PCM61
DENON DN-2000F NKS240A
DIORA CD-502 TDA1543
DUAL CD130 CX20017
DUAL CD20 PCM53
EXPOSURE CD TDA1545A
EZO FOG STAGE3 AD1853
FISCHER AD935 LC7881 SFP1
FISCHER Z1 PCM58 SFP1
GRUNDIG CD103 LC7881
GRUNDIG CD9000 TDA1541A CDM4.11(£95.00)
HARMAN KARDON HD200 YM3020
HARMAN KARDON HD500 PCM53
HARMAN KARDON HD710 MN6474
HARMAN KARDON HD720 PCM1710
HARMAN KARDON HD730 SAA7350
HARMAN KARDON HD760 PCM1702
HARMAN KARDON HD7225 MN6474
HARMAN KARDON HD7300 PCM61
HARMAN KARDON HD7325 MN6474
HARMAN KARDON HD7400/7500 KSS210A
HARMAN KARDON HD7525 PCM61P
HELIOS MODEL1S CS4328 (36 bit, ETNA)
HELIOS MODEL2S CS4328 (36 bit, ETNA)
HELIOS MODEL3S CS4328 (36 bit, ETNA)
HELIOS STARGATE CS4328 (36 bit, ETNA)
HEYBROOK SIGNATURE PCM67
HIGH TECH GOLDLINE CX904 YM3020
JVC XL V22 PCM54 OPTIMA2
JVC XL V221 LC7881 OPTIMA5
JVC XL V250BK PCM56 OPTIMA2
JVC XL V311BK MN6471 OPTIMA4S
JVC XL V464 MN35500 OPTIMA6S
JVC XL V1100 PCM54 OPTIMA1
KENWOOD DP47 TD6720N KSS152A
KENWOOD DP87 KSS152A
KENWOOD DP460 TD6709N
KENWOOD DP660SG KSS152A
KENWOOD DP730 KSS210A
KENWOOD DP850 CX20152
KENWOOD DP920/30/50 KSS210A
KENWOOD DP1030 KSS210A
KENWOOD DP1050 NKS240A
KENWOOD DP1060 RCTRH8136
KENWOOD DP1080 LC78620E
KENWOOD DP1100D CX20152
KENWOOD DP1510 PCM56 KSS210A
KENWOOD DP2000 CX20152
KENWOOD DP2010 PCM56P KSS210A
KENWOOD DP2030 KSS210A
KENWOOD DP2050 NKS240A
KENWOOD DP2060 RCTRH8136
KENWOOD DP2080 LC78620E (LC78820)
KENWOOD DP3010/30/50 KSS210A
KENWOOD DP3060 NKS240A
KENWOOD DP3080 SM5864
KENWOOD DP4030 KSS210A
KENWOOD DP4090 KAN03
KENWOOD DP5010/30/40 KSS210A
KENWOOD DP5020 PCM1701P KSS210A
KENWOOD DP5090 MN35502 JVC
KENWOOD DP7002 PCM1702
KENWOOD DP7030 CXD2552 KSS210A
KENWOOD DP7040/50 KSS210A
KENWOOD DP7060 TDA1547
KENWOOD DP7090 8x PCM1702
KENWOOD DP8020 KSS152A
KOREA CHINA CD 022 KDA0316LN
KOREA HCD 630 Y3015
KRELL KAV280 PCM1704
LINN GENKI PCM1723
LUXMAN D 102 TD6709N
LUXMAN D 103 PCM1701
LUXMAN D 112 1x PCM56
LUXMAN D2 92 LC7881
MARANTZ CD7 TDA1541AS2 (double crown)
MARANTZ CD10 SAA7310 TDA1547 CDM4/D36
MARANTZ CD11LE/II TDA1547 CDM4/D36 HDAM
MARANTZ CD1010/20 CDM12.1
MARANTZ CD14 TDA1547 CDM12.1
MARANTZ CD15 TDA1547 CDM4-MD
MARANTZ CD16D SAA7310 TDA1547 HDAM
MARANTZ CD17mkII TDA1370 TDA1547(DAC7) VAM1201 NJM2114/HDAM
MARANTZ CD19 SM5872
MARANTZ CD23 CDM9
MARANTZ CD273 CDM2
MARANTZ CD38 TDA1545 CDM12.1
MARANTZ CD385 CDM4
MARANTZ CD40 SAA7310 SAA7220 TDA1541/A CDM4/19
MARANTZ CD42 SAA7310 SAA7350 ? CDM4//691.30209
MARANTZ CD42 II CDM4
MARANTZ CD43 SM5872BS CDM12.1/05 NJM4560
MARANTZ CD45 TDA1540 CDM2/29
MARANTZ CD46 CDM12.1
MARANTZ CD48 TDA1545//1549 CDM12.1
MARANTZ CD50 TDA1541 CDM4/19
MARANTZ CD52 SAA7310 SAA7321GP CDM4
MARANTZ CD52SE SAA7310 SAA7350(Bitstream) CDM4 NE5532
MARANTZ CD53 SM5872BS CDM12.1 NJM2114
MARANTZ CD56 TDA1541 CDM4/25
MARANTZ CD57/57 II CDM12.1
MARANTZ CD583/93 CDM4/19
MARANTZ CD60 TDA1541 A CDM4/19 NE5534
MARANTZ CD63 SM5872BS CDM12.1 HDAM
MARANTZ CD63II SM5872 CDM12.1
MARANTZ CD63mkII KI SM5872 CDM12.1
MARANTZ CD63SE SM5872BS CDM12.1
MARANTZ CD65 SAA7310 TDA1541 CDM4/25
MARANTZ CD65 II SAA7210 SAA7220B TDA1541 A CDM4/19
MARANTZ CD67 SM5872 CDM12.1
MARANTZ CD67SE SM5872 CDM12.1
MARANTZ CD67II OSE SM5872 CDM12.1
MARANTZ CD72 SAA7310 SAA7350(Bitstream) CDM4/19
MARANTZ CD72mkII SE SAA7310 TDA1547 CDM 4/28//CDM4/19 HDAM
MARANTZ CD73 SAA7000/10 SAA7020 2xTDA1540 CDM1
MARANTZ CD74 SAA7000/10 SAA7020 2xTDA1540 CDM1
MARANTZ CD75 CDM4/25
MARANTZ CD75NB CDM2-160
MARANTZ CD75XNB 691.20464
MARANTZ CD80 TDA1541 CDM1/mkII(CDM4.19) single opamps
MARANTZ CD84 TDA1540 CDM1
MARANTZ CD85 CDM1/mkII
MARANTZ CD94/mkII TDA1541 CDM1
MARANTZ CD873 CDM2-0500//CDM4/11
MARANTZ CD883 CDM4/19
MARANTZ CD4000 SAA7378 TDA1545 VAM1201 NJM4560
MARANTZ CD5000 SAA7378 TDA1549 VAM1201 NJM4560
MARANTZ CD6000 SAA7378 SM5872 VAM1201 NJM2114
MARANTZ CD6000KI SAA7372 SM5872BS VAM1201 HDAM
MARANTZ CD6000OSE SAA7372 2xSM5872 VAM1201 HDAM
MARANTZ SA-12S1/SA14 CS4397 HDAM
MARK LEVINSON N'36 PCM1702 (vagy PCM1704)
MARK LEVINSON No. 390S AD1853
MERIDIAN 508 CS4329
MICROMEGA LEADER SAA7321GP
MICROMEGA LOGIC SAA7321
MICROMEGA PREMIUM18 new CS4327
MICROMEGA STAGE2 SAA7321GP
MICROMEGA STAGE6 TDA1305
MISSION dAC5 TDA1547
MISSION dAD3 TDA1305
MISSION PCM4000 TDA1541
MITSUBISHI DP109 PCM56
MITSUBISHI MC5100 PCM56
MUSICAL FIDELITY x-ray PCM1716 NE5532
MUSICAL FIDELITY Tri-Vista PCM1738 NE5532
MUSICAL FIDELITY A2 YDC103
MUSICAL FIDELITY DIGILOG TDA1541
MUSICAL FIDELITY E60 YDC103
MUSICAL FIDELITY E624 PCM1716
MYRYAD T-10 CS4327
MYRYAD T-20 CS4327
MYRYAD MC100 CXD2565
NAD 502 MN6474AM KSS210A
NAD 510 SAA7350 CDM12.1
NAD 515 CDM12.1
NAD 512 MN6474 KSS210A
NAD 522 PCM1710
NAD 5100 PCM56
NAD 5325 LC7881
NAD 5425 MN6471M
NAD C520 PCM1710
NAD S500 CS4390
NAIM AUDIO CD1 TDA1541
NAIM AUDIO CD2 TDA1541
NAIM AUDIO CD3 TDA1541
NAIM AUDIO CD3.5 TDA1305
NAIM AUDIO CD5 TDA1305
NAIM AUDIO CDI TDA1541AS1 (single crown)
NAIM AUDIO CDS11 PCM1702K
NAKAMICHI CD PLAYER 1 PCM1700P
NAKAMICHI CD PLAYER 4 AD1864N
NAKAMICHI MB 4 LC78840
NAKAMICHI MB 5 LC78840
NAKAMICHI CDP 2E TDA1541A
NAKAMICHI OMS 1E PCM56
NAKAMICHI OMS 4E PCM54
NAKAMICHI OMS 5E TDA1540
NAKAMICHI OMS 7E PCM54
NEC CD610 PCM54
ONKYO DX-704 MN6472 (Technics MASH)
ONKYO DX-6430 YM3020
ONKYO DX-6470 PCM56
ONKYO DX-6550 Integra TC9219 (ONKYO 8D-3170-1)
ONKYO DX-6570 PCM58
ONKYO DX-6620 LC7881
ONKYO DX-7011 TC9237
ONKYO DX-7211 SM5874
ONKYO DX-7500 ONKYO 8S-3380-1
ONKYO DX-7711 Integra SM5864AP
ONKYO DX-7911 Integra SM5864AP
ORELLE CD100 TDA1541
PARASOUND CD M839 PCM56
PARASOUND C/DP1000 PCM67
PHILIPS AK601/630/640/729/CCD310/320 CDM4/19
PHILIPS CD-80 TDA1541
PHILIPS CD-85M TDA1541
PHILIPS CD-94M TDA1541
PHILIPS CD-100 TDA1540 CDM0
PHILIPS CD-101 TDA1540 CDM1
PHILIPS CD-104 TDA1540 CDM0/CDM1
PHILIPS CD-115/130/140 CDM4/19
PHILIPS CD-150/1 CDM2/29
PHILIPS CD-160 CDM4/25
PHILIPS CD-162/4 CDM4/19
PHILIPS CD-163 CDM12.1/05
PHILIPS CD-200 TDA1540 CDM0
PHILIPS CD-202 TDA1540 CDM0
PHILIPS CD-204 TDA1540 CDM0
PHILIPS CD-210 TDA1543 CDM4/19
PHILIPS CD-210 CDM4/19
PHILIPS CD-300/303 SAA7210 SAA7020 2xTDA1540 CDM1
PHILIPS CD-304 TDA1540 CDM1
PHILIPS CD-304 MkII (alu chassis) SAA7210 SAA7220P/A TDA1541 CDM1
PHILIPS CD-310 CDM4/19
PHILIPS CD-340 CDM4/19
PHILIPS CD-350 TDA1541 CDM2/29
PHILIPS CD-360 CDM2 //CDM4/25
PHILIPS CD-371/3 CDM4/11
PHILIPS CD-380 TDA1543/1/1A CDM4/19
PHILIPS CD-410 CDM12.1/05
PHILIPS CD-460 TDA1541 CDM2 //CDM4/25
PHILIPS CD-465 TDA1541
PHILIPS CD-470
PHILIPS CD-471 TDA1541 CDM4/11
PHILIPS CD-472 TDA1541 CDM4/11
PHILIPS CD-473 TDA1541 CDM4/11
PHILIPS CD-480/2 TDA1543 CDM4/19
PHILIPS CD-500/2 CDM4/19
PHILIPS CD-560 CDM2 //CDM4/25
PHILIPS CD-581/2 TDA1541 CDM4/19
PHILIPS CD-583/4 CDM4/19
PHILIPS CD-586 CDM4/19
PHILIPS CD-600/4/5 CDM4/19
PHILIPS CD-610 SAA7310 SAA7220P TDA1541 CDM4/19
PHILIPS CD-604 TDA1543 CDM4/19
PHILIPS CD-614/15 TDA1543 CDM4/19
PHILIPS CD-618 Bitstream ? CDM4/19
PHILIPS CD-620 TDA1541 ? CDM4/19
PHILIPS CD-621 SAA7345
PHILIPS CD-624 SAA7323 CDM4/19
PHILIPS CD-630 SAA7220P/B TDA1541 CDM4/19
PHILIPS CD-634 Bitstream ? CDM4/19
PHILIPS CD-640 TDA1541
PHILIPS CD-650 SAA7210 SAA7220P/A TDA1541 CDM2/29//CDM4/25
PHILIPS CD-660 CDM4/11
PHILIPS CD-670 SAA7210 SAA7220P/A TDA1541 CDM4/11//(69130212) LM833 slim size,
plastic case, SPDIF
PHILIPS CD-690 Bitstream ? RCD1.2D
PHILIPS CD-692 Bitstream ? CDM9/63
PHILIPS CD-710/720 CDM12.1/05
PHILIPS CD-723 SAA7378 TDA1545 VAM1201 NJM4560
PHILIPS CD-733/740 CDM12.1/05
PHILIPS CD-751 SAA7378 TDA1549 CDM12.1/05
PHILIPS CD-750 SAA7378 TDA1549 CDM12.1/05
PHILIPS CD-753 SAA7378 TDA1549 VAM1201 NJM4560
PHILIPS CD-771 CDM2-0500//CDM4/11
PHILIPS CD-780/1 CDM4/19
PHILIPS CD-782 TDA1541 CDM4/19
PHILIPS CD-820 SAA7220 TDA1541 A CDM4/19 LM833
PHILIPS CD-830 CDM4/19
PHILIPS CD-824/834 CDM4/19
PHILIPS CD-840 Bitstream CDM4/19
PHILIPS CD-850 TDA1541 CDM4/19 LM833
PHILIPS CD-880 TDA1541 S1 CDM1 mkII
PHILIPS CD-882 CDM1 mkII//691.20449
PHILIPS CD-883 CDM4/19
PHILIPS CD-910/11 SAA7341GP (4822-691-20768) CDM12.1/05//RCD1.2D
PHILIPS CD-930/1 TDA1547 CDM9/44
PHILIPS CD-920/1 CDM12.1/05//RCD1.2D
PHILIPS CD-940 CDM9/44
PHILIPS CD-950 TDA1547 CDM9/44
PHILIPS CD-950/1 TDA1547 CDM9/44
PHILIPS CD-960 TDA1541 CDM1/mkII ??? NE5534
PHILIPS LHH-100 TDA1547
PHILIPS LHH-500 TDA1547
PHILIPS LHH-600 TDA1547
PHILIPS LHH-800 TDA1547
PHILIPS LHH-1000 TDA1541
PHILIPS MAGNAVOX CDB-560 TDA1541
PHILIPS MAGNAVOX CDB-650 TDA1541
Model Decoder DF DAC Laser Unit An.Out Comments
PINK TRIANGLE NUMERAL TDA1305T
PIONEER DV-717 PE8001A
PIONEER PD40S PWY1010
PIONEER PD75 PD2028A
PIONEER PD93 PD2028A
PIONEER PD95 PD2028A
PIONEER PD-102/3 PEA1179
PIONEER PD-202/3 PEA1179
PIONEER PD-204 PD2026B
PIONEER PD-970 PEA1030
PIONEER PD-4050 PWY1010
PIONEER PD-4500 PCM1700 PEA1030
PIONEER PD-4700/5700/6500/67000/7700/8700 PEA1030
PIONEER PD-4550 PCM1700P PEA1030
PIONEER PD-5100 PD0034 PWY1010
PIONEER PD-52 PEA1030
PIONEER PD-5300 PCM56 PWY1010
PIONEER PD-54 PEA1179
PIONEER PD-5500 PEA1030
PIONEER PD-5050 PWY1010
PIONEER PD-5700 PD2026A PEA1030
PIONEER PD-6050/6100/6300 PWY1010
PIONEER PD-65/6500/6700 PEA1030
PIONEER PD-7050 PWY1010
PIONEER PD-7300 PCM58P
PIONEER PD-7300/7500/7700/8700 PEA1030
PIONEER PDR-04 AKM4321
PIONEER PDR-609 PCM1716
PIONEER PDR-W739 PCM1716
PIONEER PDR-W839 PCM1716
PIONEER PDS-06 PCM1702J
PIONEER PD-S303 PEA1030 NJM 4558/4580
PIONEER PD-S501 PEA1030 NJM 4558/4580
PIONEER PD-S502 PD2026B PEA1179 NJM 4558/4580
PIONEER PD-S503 PEA1179 NJM 4558/4580
PIONEER PD-S505 PD2029A PEA1030 NJM 4558/4580
PIONEER PD-S507 CXD2507aq PE8001A NJM 4558/4580
PIONEER PD-S602/3 PEA1179 NJM 4558/4580
PIONEER PD-S601/701 PEA1030 NJM 4558/4580
PIONEER PD-S702 PEA1179 NJM 4558/4580
PIONEER PD-S703 PD2029A PEA1179 NJM 4558/4580
PIONEER PD-S707 PEA1030 NJM 4558/4580
PIONEER PD-S801 PD2028
PIONEER PD-S802 PD0116A PEA1179
PIONEER PD-S901 PD2028B PEA1030
PIONEER PD-S909/990 PEA1030
PRIMARE D20 AKM4324
PRIMARE D302 4x PCM1702
PROCEED PCD2 PCM58P
PROTON AC423 LC78820
PROTON AC424 TDA1311A
QUAD66 TDA1541A
QUAD77 CS4328
REGA PLANET PCM1710U
REVOX B225 TDA1540
REVOX B226 TDA1541 NE5534
REVOX C221 SAA7310
ROKSAN ATTESSA DP3P CS4328
ROKSAN CASPIAN TDA1305
ROTEL RCD-02 PCM1732
ROTEL DCM-9PRO PCM63
ROTEL RCD-855 TDA1541 CDM4/19
ROTEL RCD-856BX SAA7323
ROTEL RCD-865BX SAA7323
ROTEL RCD-945AX SAA7341GP T
ROTEL RCD-955 TDA1541
ROTEL RCD-965BX SAA7323GP T
ROTEL RCD-970BX TDA1305T
ROTEL RCD-971 PCM63
ROTEL RCD-975 TDA1305T
ROTEL RCD-991 PCM63P
ROTEL RCD-1070 PCM1732
SANSUI CD V1000 PCM56
SANYO CP489 LC7881
SEG CD200 YM3020
SHARP DX112 IR 3K16BM
SHARP DX650 LC7880
SHERWOOD CD1 TDA1547
SHERWOOD CD1060C D6372 CX
SHERWOOD CD1160R PCM56
SHERWOOD CD1192R YM4113B
SHERWOOD CDC2000C μPD6376
SHERWOOD CDC2010RC μPD6376
SHERWOOD CD4030R SAA7350BS
SIMAUDIO MOON ECLIPSE 4x PCM1704K
SONIC FRONTIERS SFCD1 UltraAnalog D20400A
SONY CDP-25/356 KSS120C
SONY CDP-203/30/45/50/55/65/70 KSS121A
SONY CDP-40 1x PCM54
SONY CDP-101 CX20017
SONY CDP-222ES PCM56P J
SONY CDP-227ESD TDA1541
SONY CDP-228ESD PCM58P KSS151A
SONY CDP-302ES CX20152
SONY CDP-333ESA CXD2562
SONY CDP-333ESD TDA1541
SONY CDP-333ESJ CXD2562
SONY CDP-337ESD 2xTDA1541A
SONY CDP-497 CXD2561
SONY CDP-502 PCM54
SONY CDP-502ES CX20152
SONY CDP-552 PCM54
SONY CDP-553ESD PCM53JP-V K
SONY CDP-555ESA CXD2562
SONY CDP-555ESD TDA1541A
SONY CDP-555ESJ CXD2562
SONY CDP-620 CX23034 PCM54
SONY CDP-650 PCM54
SONY CDP-701ES CX20017
SONY CDP-777ESA CXD2562Q
SONY CDP-M18 CXD2500Q CXD2554M KSS240A
SONY CDP-MS1 CXD8594 + CXA8042AS
SONY CDP-R3 + DAS-R1a CXD2552Q + CXD2552
SONY CDP-X229ES CXD2562Q NKS240A
SONY CDP-X3000 CXD2562Q + CXA8042AS
SONY CDP-X303ES CXD2562Q
SONY CDP-X5000 CXD2515 CXD2562 + CXA8042
SONY CDP-X505ES CXD2562Q
SONY CDP-X33ES CXD2552Q
SONY CDP-X55ES CXD2552 KSS270A
SONY CDP-X777ES CXD2552BQ
SONY CDP-X779ES CXD2562
SONY CDP-X77ES CXD2552 KSS280A
SONY CDP-X7ESD PCM58P S KSS190A
SONY CDP-X900 CXA8042
SONY CDP-XA30ES CXD2562Q + CXA8042AS KSS160B
SONY CDP-XA50ES CXA8042AS
SONY CDP-XA55ES CXD8594Q + CXA8042S KSS310A
SONY CDP-XA5ES CXD2562Q + CXA8042AS
SONY CDP-XA7ES CXD2562 + CXA8042AS
SONY CDP-XB920 CXD8715 + CXA8355
SONY CDP-XB720E CXD8735N
SONY CDP-XB930 CXD8735N
SONY CDP-XE300 CXD8567
SONY CDP-XE330 CXD2529Q
SONY CDP-XE900 CXD8505 + CXA8055 KSS213B
SONY DAS-R1 4XTDA1541AS1 (single crown)
SONY CDX11/20/80/5B KSS160B
SONY CDXA15/20/30 KSS160B
SOUND WAVE CD1100 LC7881
SUDGEN OPTIMA TDA1543
SUDGEN SDA-1 TDA1541
SUDGEN SDT-1 TDA1541AS1 (single crown)
T+A CD1210R SM5864AP
TAG McLAREN CD20R CS4329
TALK ELECTRONICS THUNDER 3 CS4390
TASCAM CD201 MN6474
TEAC PD155mk2 Y3015
TEAC PD160 TC9218F 9A01026600
TEAC CPD3450SE YDC103LSI OPAxx
TEAC CPD3100/4100 KSS210A
TEAC PD365 YM7121B
TEAC VRDS 7 TDA1547
TEAC VRDS 8 PCM1702
TEAC VRDS 9 PCM1702
TEAC VRDS 10SE TDA1547
TEAC VRDS 25 AD1862J
TEAC ZD5000 PCM53
TECHNICS SL-P1 PCM53
TECHNICS SL-P2 PCM53
TECHNICS SL-P110 PCM54HP
TECHNICS SL-P120K E PCM54HP
TECHNICS SL-P272A MN6474
TECHNICS SL-P202/212/222 CDM4/19
TECHNICS SL-P177/277/377/477 A CDM4/19
TECHNICS SL-P1200 PCM54HP
TECHNICS SL-P360/70/460/70/570 CDM12.1/05
TECHNICS SL-PG480A MN662713 CDM12.1/05
TECHNICS SL-PG100/200/400/420/440/500/520/540 CDM4/19
TECHNICS SL-PJ28A MN6477 CDM4/19
TECHNICS SL-PJ24/26/27/28/37/325/46 CDM4/19
TECHNICS SL-PS620 CDM4/19
TECHNICS SL-PS670D MN6474 CDM12.1/05
TECHNICS SL-PS700 MN6474 SOAD70A
TECHNICS SL-PS740A CDM4/19
TECHNICS SL-PS770A MN6473 CDM12.1/05
TECHNICS SL-PS840/900A SOAD70A
THETA DSP PCM67
THOMSON LAD300 TD6720N
THULE CD100 CS4303
THULE SPIRIT PCM1715U
TOSHIBA XR40 TD6705AP
UHER UCD-210 LC7882
UNIVERSUM CD4682 PCM56
USHER CD-100 PCM1732
WADIA 850 PCM1702
WADIA 860 4x PCM1702
WADIA 861 4x PCM1704
YAMAHA CD-2 PCM53
YAMAHA CD-3 PCM53
YAMAHA CD-2000 PCM54HP
YAMAHA CDX-3 PCM54
YAMAHA CDX-410 PCM56
YAMAHA CDX-420 PCM56
YAMAHA CDX-450 KSS210A
YAMAHA CDX-470 YDC103 KSS210A
YAMAHA CDX-480 MN66271 KSS210A
YAMAHA CDX-490 MN66271R
YAMAHA CDX-580 YAC514 KSS210A
YAMAHA CDX-590 YAC514
YAMAHA CDX-593 YAC514
YAMAHA CDX-700 PCM56
YAMAHA CDX-750/860 KSS210A
YAMAHA CDX-880 YAC514 KSS210A
YAMAHA CDX-900 PCM56
YAMAHA CDX-890 YAC514
YAMAHA CDX-893 YAC514
YAMAHA CDX-993 YAC514F
YAMAHA CDX-1100 PCM56
YAMAHA CDX-2020 PCM58
希望对有需要的大侠有帮助!
11fyf 在 2005-8-25 13:30:26 发表的内容
谢谢帮忙提供了莎姬的光头参数。
向雷锋同志学习嘛,呵呵
[upload=jpg]
最后编辑davidliu
谢谢帮忙提供了莎姬的光头参数。
多谢,收藏了
部份器材价格:
HIFI器材价格参考!不定期整理!
21CN A50SE 合并机 5200人民币
21CN A100 合并机 5080人民币
21CN A45 合并机 3480人民币
21CN A80 合并机 3000人民币
21CN A120 合并机 2280人民币
雅乐 普契尼 5460人民币
雅乐 普契尼特别版 7560人民币
雅乐 普契尼签名版 6650人民币
雅乐 普契尼签名特别版 9240人民币
雅乐 贝里尼前级 8200人民币
雅乐 唐采尼帝后级 10000人民币
丹麦皇子 B-100 合并机 9000人民币
架势Classe CAP151 合并机 16000人民币
力士 C-509S 合并机 39560人民币
力士 C-7I 前级 35500人民币
力士 M-7I 后级 35500人民币
力士 C-3 前级 12880人民币
力士 M-3 后级 14620人民币
力士 C-9II 前级 85380人民币
力士 B-10 后级 75520人民币
Krell 300i 合并机 18000人民币
Krell 500i 合并机 34000人民币
TAG Mc Laren 60i 合并机 7000人民币
TAG Mc Laren 60ai 合并机 9800人民币
翩美 Primare A30.1合并机 15800人民币
翩美 Primare A20 合并机 9300人民币
翩美 Primare A10 合并机 7500人民币
Mark Levinson No383 合并机 50000人民币
乐林 Concentra 合并机 36000人民币
Linn kolektor 前级 7200人民币
Linn LK85 后级 7200人民币
Bryston 4B ST 后级 21300人民币
Bryston 7B ST 后级 37000人民币
Bryston BP25 前级 17000人民币
音乐之旅ECP1前级 5400人民币
音乐之旅EC4.5前级 7860人民币
音乐之旅EC4R前级 11700人民币
音乐之旅EC4.7前级 19630人民币
音乐之旅AW600FTT后级 9650人民币
音乐之旅AW100DMB后级 17200人民币
音乐之旅AW120DMB后级 26620人民币
音乐之旅AW180M后级 24600人民币
音乐之旅ECI1合并机 16670人民币
音乐之旅ECI2合并机 6350人民币
音乐之旅ECI3合并机 12192人民币
NAD S-300 合并机 12500人民币
NAD S-100 前级 9000人民币
NAD S-200 后级 12000人民币
ONIX A-120 合并机 5500人民币
ONIX A-60 合并机 3600人民币
ONIX OA-80 合并机 4000人民币
ONIX 3000+2150前后级 7500人民币
音乐传真 X-A1 合并机 8500人民币
音乐传真 A-3 合并机 12000人民币
音乐传真 A-300 合并机 17000人民币
音乐传真 M3 合并机 38000人民币
麦景图 MC352 后级 63800人民币
麦景图 MC300 后级 43000人民币
麦景图 C15 前级 16500人民币
麦景图 MA6450 合并机  22000人民币
麦景图 MA6850 合并机 30000人民币
多能士 TIA-2300 合并机 12800人民币
金嗓子 E407V 合并机 33000人民币
金嗓子 E306V 合并机 22000人民币
金嗓子 E211 合并机 13800人民币
Bow 丹麦神弓 Wazoo 合并机 23000人民币
雅骏 FMJ A22 合并机 16000人民币
Gryphon Callisto2200 合并机 33000人民币
Gryphon Callisto2100 合并机 27000人民币
Gryphon Century 合并机 28000人民币
Gryphon TABU AT 合并机 22000人民币
Goldmund SRI-2 合并机 30000人民币
音箱报价
达尼 皇太子II   5600人民币   AE 100iLE   2500人民币
达尼 ROYAL SCEPTER   8400人民币   AE 109LE   4500人民币
达尼 皇太子370   7700人民币   AE 120   6350人民币
达尼 皇太子470   12300人民币   AE 107C(中置)   1930人民币
达尼 皇太子870   17500人民币   AE 108S(超低音)   4345人民币
达尼 ASXCENTER   1250人民币   AE 200   3850人民币
达尼 ASX 1000   1400人民币   AE 209   5860人民币
达尼 ASX 3000   2500人民币   AE 1   12360人民币
达尼 ASX 5000   3750人民币   AE 2   19300人民币
达尼 ASX 8000   5300人民币   AE 1(签名版)   26300人民币
达尼 男爵 505   4800人民币   AE 2 (签名版)   46600人民币
达尼 男爵 606   6000人民币   AE 5   99200人民币
达尼 男爵 808   7400人民币   AE 509   11860人民币
达尼 子爵 SUITE 1.5   6400人民币   AE 520   15330人民币
达尼 子爵 SUITE 2.5   8700人民币   AE 水晶一号   1960人民币
达尼 子爵 SUITE 3.5   12700人民币   AE 水晶二号   2960人民币
达尼 子爵 中置   3500人民币   法国 三角牌 TITUS-TZX   4800人民币
达尼 子爵超低音   4300人民币   法国 三角牌 COMETE-TZX   6100人民币
雅丽丝 1号 音箱   18800人民币   法国 三角牌 LUNN   6800人民币
雅丽丝 2号 音箱   28800人民币   法国 三角牌 ZEPHYR   9000人民币
KEF CRESTA 1 音箱   1900人民币   法国 三角牌 ITTOHxs   11600人民币
KEF CRESTA 2 音箱   2600人民币   法国 三角牌 ANTAL   12400人民币
威武 极典 Solus   16000人民币   法国 三角牌 ZAYS MKII   22000人民币
威武 时尚谱乐   14500人民币   法国 三角牌 EXTAN   34000人民币
威武 时尚百乐   11000人民币   法国梦幻之声 Initiation 1   2340人民币
威武 时尚意乐   5000人民币   梦幻之声 Initiation 2   3900人民币
Spendor S2   4536人民币   梦幻之声 Initiation 3   5200人民币
Spendor 2020   3460人民币   梦幻之声 Initiation 4   3280人民币
Spendor 2030   4950人民币   梦幻之声 Initiation 6   3770人民币
Spendor 2040   7730人民币   梦幻之声 Initiation 7   5200人民币
Spendor SP3/1P(红木)   9185人民币   梦幻之声 Initiation 中置   1800人民币
Spendor SP1/2(桃木)   14184人民币   丹拿 听众42   5500人民币
美之声监听一号   3800人民币   丹拿 听众52   6500人民币
美之声监听三号   4780人民币   丹拿 听众62   8000人民币
美之声焦点十号   1270人民币   丹拿 听众72   11000人民币
美之声和谐三号   2720人民币   丹拿 听众82   14000人民币
美之声梦幻三号   3780人民币   丹拿 CONTOUR1.1MKII   9800人民币
B&W N805   14000人民币   丹拿 CONTOUR1.3MKII   13500人民币
B&W N804   28000人民币   丹拿 CONTOUR1.3SE   22000人民币
B&W N803   35000人民币   丹拿 CONTOUR1.8MKII   20000人民币
B&W CDM1NT   8800人民币   ProAc T2000   7600人民币
B&W CDM7NT   14000人民币   ProAc T2000 签名版   9600人民币
B&W CDM1SE   6800人民币   ProAc 1SC   11600人民币
卓丽贵族世代一号   13500人民币   西湖 LC6.75   13200人民币
皇冠 鉴名三号MKII   13500人民币   西湖 LC5.75   9600人民币
CD机和咸菜报价
CD机
马兰士 CD6000OSE CD机  2550人民币
马兰士 CD19A CD机  4000人民币
马兰士 CD17DA CD机  5400人民币
马兰士 CD16D CD机  7000人民币
天龙 DCD-S10II CD机  9600人民币
天龙 DVD5000 DVD机  14500人民币
天龙 DVD1000 DVD机  3300人民币
雅乐巴格里尼 CD机  7500人民币
NAD S500 CD机  9500人民币
君子 行星 CD机  7200人民币
力士 D-600S CD机  12880人民币
力士 D-7 CD机  25640人民币
雅骏 FMJ CD23 CD机  16000人民币
CARY CD303 CD机  7000人民币
CARY CD306 CD机 19700人民币
架势Classe CDP.3II CD机  12800人民币
先锋 DV-3300 DVD机  1780人民币
先锋 DV-S10A DVD机  15800人民币
先锋 DV-S6D DVD机  6800人民币
美国 雅卓 UCD-100 CD机  6500人民币
美国 雅卓 HDCD-10 解码器  5500人民币
TEAC 25XS CD机  9100人民币
TEAC 50X CD机  13500人民币
SONY SCD-1 SACD机  30000人民币
SONY SCD-777ES SACD机 19500人民币
SONY SCD-555ES SACD机  13500人民币
SONY DVP-9000ES DVD机 12500人民币
SONY CDP-XA7ES CD机  14500人民币
SONY CDP-55ES CD机  7500人民币
翩美 1.0 DVD机  11000人民币
咸菜
NBS STINGHER
1mRCA信号线1050人民币
NBS DRAGON/FLY 小飞龙系列:
1m RCA 信号线1550人民币
1.5m RCA 信号线2000人民币
1m XLR 信号线1995人民币
1.5m XLR 信号线2500人民币
2.5m 音箱线2400人民币
3m 音箱线2900人民币
1.5m 电源线 1500人民币
NBS MINE/SERPENT-II 小蛇系列:
1m RCA 信号线2350人民币
1.5m RCA 信号线2960人民币
1m XLR 信号线2800人民币
1.5m XLR 信号线3600人民币
2.5m 音箱线3100人民币
3m 音箱线3200人民币
1.5m 电源线 2400人民币
NBS SERPENT-II中蛇系列:
1.5m RCA 信号线4500人民币
2m RCA 信号线5500人民币
1.5m XLR 信号线4500人民币
2m XLR 信号线5500人民币
1.5m 电源线 3000人民币
NBS KING/SERPENT-II蛇王系列:
1.5m RCA 信号线7900人民币
2m RCA 信号线9600人民币
1.5m XLR 信号线7900人民币
2m XLR 信号线9600人民币
2.5m 音箱线10000人民币
3m 音箱线12000人民币
NBS SIGNATURE-II签名系列:
1.5m RCA 信号线9600人民币
2m RCA 信号线12000人民币
1.5m XLR 信号线9600人民币
2m XLR 信号线12000人民币
2.5m 音箱线14400人民币
3m 音箱线16000人民币
1m 电源线 4000人民币
MASTER-II大师系列:
AQ Coral水蟒 1m XLR1140人民币
1.5m RCA 信号线12000人民币
2m RCA 信号线18000人民币
1.5m XLR 信号线12000人民币
2m XLR 信号线18000人民币
2.5m 音箱线26000人民币
3m 音箱线33000人民币
1m 电源线 5800人民币
注意: NBS 小蛇 以下报价偏高,只供参考。以下为香港区报价,未打折。
AQ Python绞蝮蛇 1m XLR3900人民币
AQ Python绞蝮蛇 1.5m XLR4800人民币
NBS Monitor0 4尺 信号线27000港元
NBS Monitor0 6尺 信号线34000港元
NBS Monitor0 8尺 音箱线54000港元
NBS Monitor0 10尺 音箱线68000港元
NBS Monitor0 6尺 电源线16800港元
NBS MonitorI 4尺 信号线13800港元
NBS MonitorI 6尺 信号线16800港元
NBS MonitorI 8尺 音箱线27000港元
NBS MonitorI 10尺 音箱线34000港元
NBS MonitorI 6尺 电源线11000港元
NBS MonitorII 4尺 信号线10000港元
NBS MonitorII 6尺 信号线12800港元
NBS MonitorII 8尺 音箱线18000港元
NBS MonitorII 10尺 音箱线22800港元
NBS MonitorII 6尺 电源线5600港元
NBS MonitorIII 4尺 信号线7800港元
NBS MonitorIII 6尺 信号线9800港元
NBS MonitorIII 8尺 音箱线11000港元
NBS MonitorIII 10尺 音箱线13800港元
NBS MonitorIII 6尺 电源线4200港元
NBS MonitorIV 4尺 信号线3200港元
NBS MonitorIV 6尺 信号线4000港元
NBS MonitorIV 8尺 音箱线3800港元
NBS MonitorIV 10尺 音箱线4800港元
NBS MonitorIV 6尺 电源线3200港元
AQ Jade翡翠 1m RCA406人民币
AQ Jade翡翠 1.5m RCA460人民币
AQ Turquoise 2绿松 1m RCA 600人民币
AQ Turquoise 2 1.5m RCA670人民币
AQ Topaz 2黄玉 1m RCA840人民币
AQ Topaz 2黄玉1.5m RCA960人民币
AQ Coral水蟒 1m RCA1140人民币
AQ Coral水蟒 1.5m RCA1340人民币
AQ Coral水蟒 1.5m XLR1340人民币
AQ Viper响尾蛇 1m RCA1650人民币
AQ Viper响尾蛇 1.5m RCA 2000人民币
AQ Viper响尾蛇 1m XLR1650人民币
AQ Viper响尾蛇 1.5m XLR2000人民币
AQ Python绞蝮蛇 1m RCA3900人民币
AQ Python绞蝮蛇 1.5m RCA4800人民币
AQ Anaconda 1m RCA 7800人民币
AQ 菱背响尾蛇 1.5m RCA11200人民币
AQ Anaconda 1m XLR 7800人民币
AQ 菱背响尾蛇 1.5m XLR11200人民币
AQ Type4 2.5m 音箱线 1180人民币
AQ Type4 3m 音箱线 1480人民币
AQ CV-4 2.5m 音箱线 2000人民币
AQ CV-4 3m 音箱线  2600人民币
AQ CV-4 2.5m分音 音箱线2400人民币
AQ CV-4 3m分音 音箱线 3000人民币
AQ Slate 2.5m 音箱线 2300人民币
AQ Slate 3m 音箱线  2900人民币
AQ Slate 2.5m分音 音箱线2700人民币
AQ Slate 3m分音 音箱线3300人民币
AQ BedRock 2.5m 音箱线3100人民币
AQ BedRock 3m 音箱线3900人民币
AQ BedRock 2.5m分音 音箱线3500人民币
AQ BedRock 3m分音 音箱线4300人民币
AQ Granite 2.5m 音箱线4000人民币
AQ Granite 3m 音箱线5000人民币
AQ Granite 2.5m分音 音箱线4400人民币
AQ Granite 3m分音 音箱线5400人民币
AQ ExtremeClear2.5m 音箱线9840人民币
AQ Extreme Clear 3m 音箱线12320人民币
AQ Extreme Clear2.5m分音 10640人民币
AQ Extreme Clear3m分音 13120人民币
AQ Sterling SE 2.5m 音箱线12600人民币
AQ Sterling SE 3m 音箱线 15400人民币
惠普线材 K33 音箱线680人民币
惠普线材 K66EX 音箱线850人民币
惠普线材 P33 电源线450人民币
惠普线材 P66EX 电源线650人民币
惠普线材 G22 讯号线350人民币
惠普线材 G44EX 讯号线550人民币
惠普线材 G33 讯号线450人民币
惠普线材 G66ES 讯号线650人民币
英国REGA君子牌音响器材价格表 2005.06.30止
型号        产品说明                零售价[元]
Planet行星        金属铝壳,不锈钢CD压,24BIT解码,遥控                7,990
Jupiter木星        金属铝壳,不锈钢CD压,双24BIT解码,光纤/同轴数码输出,遥控  16,800
Brio爱美        38WX2,100W/2欧姆,金属铝壳                4,900
Mira3爱神3        60WX2,电子音量控制,遥控                9,000
Cursa3爱歌3 前级,电子音量及选讯,动磁唱头放大        9,700
Mais3爱马3         后级,85WX2                8,600
Exon3爱玲珑3 单声道后级,120W/8欧姆,200W/4欧姆        18,000
P2黑版        LP密纹唱盘,带Bias动磁唱头        4,500
P3黑版        LP密纹唱盘,升级新马达        5,500
P5        玻璃转盘唱盘        11,300        替代P25
TTPSU        P5电源升级版        2,600
P7        陶瓷LP唱盘                19,800
P9            顶级陶瓷LP密纹唱盘        32,500
RB-1000        顶级唱臂                       14,600
RB-700        唱臂                        6,900
RB-300        唱臂                        3,000
Bias巴斯        动磁唱头                         750
Elys绮丽        动磁唱头                         1,400
SuperElys超丽 动磁唱头        2,400
Exac精确        动磁唱头                    4,000
Fono[MM]        动磁唱头放大器        2,700
Fono[MC]        动圈唱头放大器        3,200
Belt胶带        适用于君子LP电唱机        250
Mat防静电垫 适用于君子LP电唱机        200
Ear        耳机放大器         2,500
Radio3        AM/FM收音头        5,900
C.E.C
CD-3300    2860元
CD-899    1430元
TL51ZMKII    6950元
TL51XZ    7950元
剑桥
cd540C    3600元
cd640C    4500元
马兰士
cd6000 ose le    2900元
cd19DA    3680元
cd17MKIII    5650元
SA8400    6800元
PM17SA    6950元
PM8100    4780元
PM17 MKII KI    10850元
SM-17    5850元
SR4400    2580元
SR5400    3950元
ATC
SCM7    6880元
SCM10.2    13800元
SCM12    13380元
SCM20SL    27300元
雨后初晴
P3ES-2    7380元
SHL5    161500元
M30    16150元
SIM audio
I-3    15300元
I-5    20800元
Nova cd     21300元
音乐传真
A3.2cd    8800元
A3.2功放    9880元
A308    19XXX元
A308CR CD    21XXX元
A308CR前后级    15000/31000元
PMC
TB2(樱桃)    86XX元
FB1    17XXX元
LB1    183XX元
AB2    298XX元
世霸
Concertino小协    7680元
Concertino大协    12300元
toncertino    12500元
minima concect    12980元
丹拿
52se    9500元
C1.3IISE    21800元
听众62    9500元
麦拿伦
60I    6580元
SEK(丹麦神弓)
SYMPHONY    38000元
CONCERTO    28000元
PRELUDE    19500元
creek(朗泉)
cd50MKII    8780元
5350se    8980元
OBH15    2260元
OBH18    1680元
OBH 21    1850元
4330MKIII    3980元
思奔达
S3/5    5680元(车梨)、6580元(红木)
3/1P    8680元(车梨)、9280元(红木)
1/2    18300元(车梨)、19800元(红木)
SP100    28600元(车梨)、32880元(红木)
达尼
皇太子20周年纪念版    停产
皇太子落地版(钢琴漆)    9850元(特价)
皇储    8X00元
TAD
TSM300    8800元
雅骏
FJMcd33    13800元
cd73T    5880元
CD93T    10850元
Meridian (英国之宝)
G07 cd    25800元
G08 cd    35800元
exposure(英国力宝声)
2010cd    6950元
2010合并功放    7350元
2010纯后    7350元
QUAD(英国国都)
99cd    5680元
99CD-P    8980元
909后级    8300元
909单声道后级    17800元/对
99+99前后级(特价)    10X00元
99+909前后级(特价)    13X00元
QC24+909前后级(特价)    15X00元
11L    4150元
12L    5580元
21L    7X00元
22L    8X00元
L-Centre    3380元
AAD
C100i    1650元
C200i    1990元
S1    4900元
注:以上为总代理的统一零售价!
meldoy
SP3    3380元
H34    3980元
H88    4850元
JK-TAD
PM-10    24800元
audioquest(美国线圣)
讯号线(凡未特别注明,均为1M标准RCA)
DIAMOUNDBACK    1080元
KING COBRA 眼镜王蛇    1280元
JAGUAR 美洲虎    2380元
PANTHER 黑豹    4380元
CHEETAH 猎豹    6180元
SKY 晴空    11800元
喇叭线(凡未特别注明,均为2.5M标准Y叉)
Type 4    730元
CV4    1360元
CV6    1950元
bedrock 基岩    1600元(特价)
CV-6 DBS    3080元
Gibraltar    停产
PIKES PEAK    6080元
MONT BLANC    12080元
注:没有特别注明的,DBS线均为最新的36V“终极版”,价格已经做了调整。
PS audio
电源线(凡未特别注明,均为2M标准)
POWER PUNCH    1280元
Statement MKII    4580元(1.5M)
Siltech(荷兰银彩)
讯号线(凡未特别注明,均为1M标准)
LONDON IC    1480元
PARIS IC    2350元
NEW YORK IC    3050元
喇叭线(凡未特别注明,均为2.5M标准)
LONDON SC    2980元
PARIS SC    4250元
NEW YORK SC    5380元
LS-38G3    5950元
LS-80G3    9080元
LS-120G3    21380元
电源线(凡未特别注明,均为2.0M标准)
Berlin    2080元
SPO-12    2830元
SPX20M    3830元
SPX-20(G5系列)    4250元
SPX30SI    5600元
VDH(荷兰范登豪)
讯号线(凡未特别注明,均为1M标准)
D-102 III    1080元
THE WELL    1530元
INTEGRATION    2580元
INSPIRATION    8600元
The BREEZE    4580元
D-352    185元/M
clearwter 清水    75元/M
红衣主教    285元/M
CS-122    128元/M
MAINSSTREAM    3650元
MAINSSTREAM BS    2880元
Kimber(美国金宝)
讯号线(凡未特别注明,均为1M标准)
PBJ    680元
Hero    1380元
Silver Streak    1750元
KS-1011    3250元
KCAG    3250元
4TC    1550元
8TC    2350元
8PR    1150元
XLO(美国至高)
讯号线(凡未特别注明,均为1M标准)
pro 125    480元
pro 150    780元
pro 100    1250元
pro 102    1180元
Ultra 1    1680元
Ultra 1S    1980元
pro 650F    980元
Pro 600    1130元
Pro 1200    1960元
Ultra 6    2380元
Ultra 12    3680元
Ultra 12B    3980元
Straightwire(美国忠实)
讯号线(凡未特别注明,均为1M标准)
Flexconnect II    380元(特价)
Symphony    630元(特价)
ZU(美国主导)
讯号线(凡未特别注明,均为1.82M标准)
Disco(铜)    730元
Oxyfuel(超值推荐!)    1350元
Gede(B3银合金)    2250元
Varial(B3银合金)    4880元
喇叭线(凡未特别注明,均为3.0M标准)
Gauge(铜)    1150元
Julian(铜)超值推荐!    2450元
Wax(B3铜)超值推荐!    4800元
Libtec(B3银合金/铜)    7880元
Ibis(B3银合金)    10830元
ST.Julian(铜)    2950元
Birth(铜)超值推荐!    1380元
Bok(B3银合金)    2180元
Mother(B3银合金)    3630元
JUMERS 音箱桥线(均为4支一套)超值推荐!
Wax(B3铜)    630元
Ibis(B3银合金)    980元
senwheiser HD650、HD600、HD580专用耳机线 Mobius(B3银合金)
2.5M    1950元
3.0M    2080元
Audio note
讯号线(凡未特别注明,均为1M标准)
LEXUS    2500元
新德克
FS-0.5    730元
FS-1    980元
FS-2    1530元
电源线(凡未特别注明,均为1.5M标准)
FP-1    680元
东方之声
Natural 自然9号    580元
悟道
讯号线(凡未特别注明,均为1.25M标准)
WL-150R    630元
wl-250    860元
电源线(凡未特别注明,均为1.25M标准)
PW-150    450元
PW-160    580元
钟神
讯号线(凡未特别注明,均为1M标准)
JASC-02(RCA)    180元
JASC-02(XLR)    320元
JSPC-01M    450元
JPOC-03    230元
八达
HP20起跑线    280元
HP30飞跑线    380元
欧博
ELLA    450元
声美力
化震层板系列
MP-1000(黑檀)    1950元
Q-1(檀木)    880元
避震钉系列(未经特别注明,均为 3只/套)
C100(金属钉)    500元
C101(金属底座)    300元
C4(不倒翁)    280元(4只/套)
C5(金属钉)    180元
C1(小铜座)    50元(1只/套)
MC88(黑檀)    600元
C8(黑色)    330元
C8(黑桃)    220元
C2(酸枝)    120元
器材架系列(以下价格均为统一定价的7折代购价)
T1-1 规格说明:口字架,一格两层,尺寸60X50X33
低等木皮(1200元):纯黑
中等木皮(1600元):花梨,红榉,黑桃,酸枝,樱桃
高等木皮(2300元):白榉,巴西酸枝,求纹花梨,枫木,紫杉
极品木皮(2800元):雀眼,枫木树根,黑桃树根
T1-2 规格说明:日字架,两格三层,尺寸60X50X55
低等木皮(1600元):纯黑
中等木皮(2000元):花梨,红榉,黑桃,酸枝,樱桃
高等木皮(2400元):白榉,巴西酸枝,求纹花梨,枫木,紫杉
极品木皮(3000元):雀眼,枫木树根,黑桃树根
T1-3 规格说明:目字架,三格四层,尺寸60X50X75
低等木皮(2000元):纯黑
中等木皮(2400元):花梨,红榉,黑桃,酸枝,樱桃
高等木皮(2800元):白榉,巴西酸枝,求纹花梨,枫木,紫杉
极品木皮(3400元):雀眼,枫木树根,黑桃树根
T2-4 规格说明:田字架,两列两层四格,尺寸120X60X55
低等木皮(3200元):纯黑
中等木皮(3800元):花梨,红榉,黑桃,酸枝,樱桃
高等木皮(4200元):白榉,巴西酸枝,求纹花梨,枫木,紫杉
极品木皮(4800元):雀眼,枫木树根,黑桃树根
其他校声配件
B1谐波再生板    1050元
B2驻波黑洞    850元
V4发烧电源排插    1680元
君子
黑武士系列音箱架
H70-2025    1050元
H60-2025    980元
H45-2025    900元
H35-2025    850元
H70-1823    1030元
H60-1823    950元
H50-1823    850元
H18-1823    800元
H70-1619    1000元
H60-1619    950元
H18-1619    750元
H18-2025    850元
双柱和谐系列音箱架
H70-1823    850元
H60-2023    850元
双柱太子系列音箱架
H60-1823    750元
H70-1620    750元
H60-1620    750元
城堡系列音箱架
H56-2023    580元
H51-2023    550元
H45-2023    500元
特别设计专用音箱架系列
SP-100    1350元
SP-1/2    1130元
HL5    1180元
HL-7ES    1250元
801    1280元
802    1050元
架皇系列机架
D3 单仓三层 W50 X D42 H30/H20(第一层/第二层)    680元
D4 单仓四层 W50 X D42 H20/H15/15(第一层/第二层/第三层)    780元
S3 双仓三层 W90 X D42 H25/15(第一层/第二层)    880元
备注:上表架皇系列机架零售价不包含每层石板价格。出于运输安全考虑,建议客户自己在当地石材市场定做切割,厂家推荐选择厚度为2cm的“细金砂”花岗岩。
艺特
器材架系列
11-E630-A/B    950元
11-E630-2A/B    1050元
11-E800-A    1050元
11-T02    880元
11-D300-3A1    880元
11-D6003W-D    780元
E330-B    800元
T560-B    750元
T360-A    900元
T360-B-2    1050元
T660-Y    2050元
T360-Y    1950元
T01    650元
T02    880元
T03    1550元
脚架系列
22-B805    550元
22-F100    550元
HUBBELL美国“合宝”电源公插
HBL8215C    175元/只
HBL5965VBLK    135元/只
SCHURTER瑞士“舒尔特”电源尾插
NO.4781.0100    85元/只
TAKY台湾得琦MIC(麦克风)
MS100    330元/支
M85    停产
劲浪全系列价格单
型号                          单位    专卖店零售价
GRANDE超级至尊          对         640000
NOVA新一号                对         309000
ALTO新二号                对          155000
MICRO迷你                  对          51500
CENTRALE中置             只          52300
MU脚座                       对          11900
SCU STAND中置脚座     只          6000
946                            对          66700
936                            对          51200
926                            对          35650
906                            对          17780
SR900                        对           18830
CC900                        只           11180
CC901                        只           16700
SW900                       只           16700
826S                          对           22200
816S                          对           16350
806S                          对           9400
CC800S                      只            5850
SR800S                      对            8200
SW800S                     只            11700
726S                          对            11800
716S                          对            8950
714S                          对            7180
707S                          对            5300
706S                          对            4250
705S                          对            3400
SW700S                     只            6500
CC700S                      只            3200
CC70S                        只            2450
美国麦景图(McIntosh)价格:
MA6500   报价:人民币31500元
MA6900   报 价:人民币44000元
C45       报价:人民币39900元
C46       报价:人民币47500元
MC252     报价:人民币42800元
MC352     报价:人民币52600元
MC402     报价:人民币59800元
MVP851     报价:人民币32200元
MHT200     报价:人民币62800元
思奔达音箱国内统一零售价(从2005年5月1日起执行)
“classic”经典系列:
S3/5(车梨木)               9,090/对
SP3/1(车梨木)           15,240/对
SP2/3(车梨木)           21,400/对
SP1/2(车梨木)           31,300/对
SP100(车梨木)           54,540/对
S3/5(红木)                10,430/对
SP3/1(红木)              17,380/对
SP2/3(红木)              24,590/对
SP1/2(红木)              36,080/对
SP100(红木)              62,570/对
SP脚架    SP100专用脚架     7480/对
S3/5SE签名版(黑檀木) 16,830/对
“Se”系列
型号                              颜色             国内统一零售价
S3e                            樱桃木色            13,190/对
S5e                            樱桃木色            18,800/对
S6e                            樱桃木色            23,850/对
S8e                            樱桃木色            30,880/对
S9e                            樱桃木色            47,700/对
C5c(中置)                樱桃木色            11,200/只
C9c(中置)                樱桃木色            22,460/只
SR5(环绕箱)             樱桃木色            9,540/只
Sub-3(有源低音炮)    樱桃木色&黑色    12,050/只
天龙AVR-1804 市场参考价:4300元 会员价:3400元
天龙AVR-2105 市场参考价:4900元 会员价:3800元
天龙AVR-2805 市场参考价:6800元 会员价:6400元
天龙AVR-3805 市场参考价:9800元 会员价:8200元
雅马哈5730 市场参考价:2300元 会员价:1600元
雅马哈5740 市场参考价:2850元 会员价:2100元
雅马哈5750 市场参考价:3350元 会员价:2300元
雅马哈RX-V350 市场参考价:1800元 会员价:1650元
雅马哈RX-V450 市场参考价:2600元 会员价:2100元
雅马哈RX-V550 市场参考价:2800元 会员价:2300元
雅马哈RX-V650 市场参考价:3900元 会员价:3650元
雅马哈RX-V750 市场参考价:4400元 会员价:3900元
雅马哈RX-V1500 市场参考价:6200元 会员价:5500元
雅马哈RX-V2400 市场参考价:7700元 会员价:6700元
雅马哈DSP-Z9 市场参考价:39800元 会员价:32000元
安桥TX-SR602 市场参考价:5200元 会员价:4200元
安桥TX-SR701 市场参考价:6400元 会员价:5300元
马兰士SR3500 市场参考价:2300元 会员价:1900元
马兰士SR4400 市场参考价:2300元 会员价:2200元
马兰士SR6400 市场参考价:4500元 会员价:3900元
马兰士SR7400 市场参考价:6600元 会员价:5400元
纯功放:
Ayre AX-7 市场参考价:38000元 会员价:22450元
Ayre k5x 市场参考价:37800元 会员价:22450元
Ayre V-5x 市场参考价:58000元 会员价:34500元
Ayre K-1x 市场参考价:87000元 会员价:52500元
Ayre V-1x 市场参考价:111300元 会员价:67000元
雅骏A65 市场参考价:5500元 会员价:4900元
雅骏A80 市场参考价:11000元 会员价:7700元
雅骏A90 市场参考价:14000元 会员价:10300元
雅骏FMJ A32 市场参考价:18000元 会员价:15300元
欧尼士A60MKII 市场参考价:4300元 会员价:3400元
欧尼士A120MKII 市场参考价:5600元 会员价:4400元
麦景图MA6900 市场参考价:48000元 会员价:36000元
马兰士PM7200 市场参考价:4250元 会员价:2950元
马兰士PM17SA 市场参考价:7700元 会员价:5800元
马兰士PM14SA 市场参考价:15800元 会员价:11200元
Sim audio i3 市场参考价:26800元 会员价:16000元
Sim audio i5 市场参考价:39800元 会员价:26000元
JADIS Orchestra Signature 市场参考价:30000元 会员价:21000元
CD机:
CEC 3300 市场参考价:2980元 会员价:2650元
马兰士CD5400 市场参考价:2300元 会员价:1900元
马兰士CD6000 市场参考价:3200元 会员价:2100元
马兰士CD7300 市场参考价:3800元 会员价:2900元
马兰士CD19A 市场参考价:4400元 会员价:3700元
马兰士CD17MKIII 市场参考价:6600元 会员价:4900元
马兰士SA8400 市场参考价:7700元 会员价:5900元
雅骏CD73T 市场参考价:7090元 会员价:5200元
雅骏CD93T 市场参考价:15700元 会员价:10680元
雅骏FMJ CD33 市场参考价:19930元 会员价:13560元
Wadia W302 市场参考价:65000元 会员价:36000元
Wadia 861 Basic 市场参考价:910000元 会员价:54000元
Wadia 861 Standard 市场参考价:123000元 会员价:71500元
Ayre CX-7 市场参考价:38000元 会员价:22450元
Jadis Symphonia Inox 市场参考价:32110元 会员价:22500元
欧尼士CD2 市场参考价:6980元 会员价:5800元
低音炮:
JBL E150P 市场参考价:3800元 会员价:3600元
JBL E250P 市场参考价:4700元 会员价:4400元
杰士RW-8 市场参考价:5500元 会员价:3850元
杰士RW-10 市场参考价:7800元 会员价:5460元
杰士RW-12 市场参考价:10000元 会员价:7000元
杰士RSW-12 市场参考价:20000元 会员价:14000元
美声m3as 市场参考价:4300元 会员价:3500元
美声m5as 市场参考价:7400元 会员价:5900元
美声78as 市场参考价:7900元 会员价:6700元
意力101.2 市场参考价:3200元 会员价:2600元
意力111.2 市场参考价:3800元 会员价:2600元
敏特声308 市场参考价:3500元 会员价:2800元
敏特声309 市场参考价:4900元 会员价:4200元
敏特声907 市场参考价:4200元 会员价:3900元
德高VITAS SUB25A 市场参考价:4980元 会员价:3820元
MJ PRO 50 市场参考价:4600元 会员价:3400元
MJ PRO 100 市场参考价:8900元 会员价:7900元
MJ Reference100 市场参考价:5800元 会员价:4800元
MJ Reference150 市场参考价:9200元 会员价:5700元
MJ ReferenceI 市场参考价:11400元 会员价:8500元
混响器:
唐颂Ts-09 市场参考价:980元 会员价:780元
永真68 市场参考价:980元 会员价:750元
永真98 市场参考价:1380元 会员价:980元
脚架:
霸比图3F-360 市场参考价:420元 会员价:230元
意力国产支架 市场参考价:420元 会员价:260元
意力原装卫星支架 市场参考价:850元 会员价:600元
