请教:两声道解码器的问题 [复制链接]
查看: 2697|回复: 2
在香港出的《HIFI音响》上看到介绍一款解码器:Stello DA-220,坛里可有高人用过,请谈谈性能,广州是否有卖?价钱多少?
[upload=jpg]Upload/200510141544623687.jpg[/upload][upload=jpg]Upload/20051014155386913.jpg[/upload][upload=jpg]Upload/200510141553558772.jpg[/upload]
2005 CES大奖
Newcomer April Music impressed two SoundStage! writers with its Stello-brand products in 2004. Doug Schneider wrote that the Stello DA200 DAC was "rich with features and approaches cost-no-object sound -- both for a bargain-shopper’s price." About the DP200 DAC/preamp, Tim Shea said, "That you get all the DP200's flexibility, build quality and astounding performance for less than two large borders on the absurd." Accepting the Best Product Debut award are (left to right) Adam Sohmer, Simon Lee, Um Tai-Won and E.J. Lee.
最后编辑leslie
Features
  - Supports 44.1kHz/16Bit (Bypass), 48kHz, 96kHz and up to 24bit / 192kHz Upsampling (Sampling Rate Selectable)
- True 24 Bit Delta-Sigma DAC
- Sixth Order Digital Filter
- Digital Outputs for Recording
- Phase Selection : 0, 180 Degree
- On-chip PLL eliminates Jitter
- Separate transformers for analog and digital circuits
- Full Balanced, Full Class A operation Analog Output Modules
- High quality electronic components and gold plated RCA connectors
  Specifications
  Digital Inputs Coax1, Coax2 (2 RCA Unbalanced) Inputs : 75Ohm
AES/EBU (XLR) Balanced Input: 110Ohm
Toshiba Link Optical Input
  Digital Outputs Coax1, Coax2 (2 RCA Unbalanced) Outputs
AES/EBU (XLR) Balanced Output
Toshiba Link Optical Output
  Analog Outputs 1 RCA unbalanced stereo, 1 XLR balanced stereo
  Analog Output Voltage 1.3 V rms
  Output Word Length 16, 18, 20, 24bits
  Dynamic Range 110 dB Typ.
  Signal-to-noise Ratio 120 dB Typ.
  Distortion 0.003 %, 1 kHZ
0.002 %, 10 kHZ
0.002 %, 20 kHZ
  Frequency Range 10 Hz - 55 kHz ( +- 3 dB )
  Sampling Frequency 44.1kHz to 192kHz, Selectable 192kHz default
  Power Requiremnets 100/120/220/230 VAC, 60Hz Selectable
  Dimension 435 x 85 x 345 (WHD) mm
  Weight 8 Kg
[upload=jpg]Upload/2005101414591834599.jpg[/upload][upload=jpg]Upload/2005101414594063526.jpg[/upload][upload=jpg]Upload/20051014150399643.jpg[/upload]
韩国制造,细节充分的很,高透明度。W元价位
最后编辑leslie
