Luxman PD-277 黑胶唱盘(图) [复制链接]
查看: 2595|回复: 4
今天在广州看到很多力士唱盘,其中一款PD-277才卖1400元,大家觉得怎么样?
[upload=jpg]Upload/2005104022072344.jpg[/upload]
Luxman PD370
[upload=jpg]Upload/20051040134593483.jpg[/upload][upload=jpg]Upload/20051040135666474.jpg[/upload]
这个看上去像是二手的?假如是二手的话,不管是什么牌子,直驱或者皮带,要注意检查一下马达转速是否稳定。马达属于损耗性部件,不少使用多年的中低档转盘的马达都存在转速不稳定的情况(尤其是没有电子恒速的那些)。检查的时候不能只是播放几分钟听听就了事,要让它工作上一两个小时。我见过最坏的一个例子便是有台也是二手的,听了一个星期之后马达才露出转速的问题。
Luxman model PD-277 turntable. Includes Adcom moving coil pickup. Requires MC type phono preamp. We suspect this turntable has had little use, it was discovered in the basement of a radio station with a note on it that said "not broadcast quality". Indeed, it is beyond broadcast quality. With the MC cartridge installed it probably sounded poor on their MM phono preamps. Although it is funtionally perfect and in good cosmetic condition, it would benefit from a good Q-tip cleaning and dust cover polishing. Some of the veneer on the front appears to be starting to lift. See also matching preamplifier and amplifier and tuner.
Fully Automatic
Direct Drive
Speed Strobe
33 and 45 Speeds
Speed Calibration Controls
Function Switch: Repeat, Auto, Manual
Shipping Weight: 20 lbs.
