麻子和baiteng请进——快看你们的升级目标! [复制链接]
查看: 4826|回复: 11
好东西,几米:)PM我谢谢
VIP G2 - Audionet's player statement
VIP G2 是部真正 Universal 的唱盤,不僅能解讀所有的 CD、DVD 格式光碟片,VIP G2 亦能讀取 SACD,解碼兩聲道或多聲道。在聲音表現上,VIP G2 演譯各類資訊規格,提昇音色至全新境界;在影質成像上,VIP G2 更展現活生、亮麗而穩定的高品質畫面。成功結合影、音聲色場景之感染,VIP G2 帶來前所未有的劇院聆賞經歷。
What's fresh in VIP G2
• Universally accept all format CD/ DVD/ SACD
  [所有的片子都讀]
• Top-Loading Mechanism
  [全新的鋁合金上掀承蓋設計,厚達 10mm,還有獨到的"類鐵弗龍"盤鎮- POM]
• Audionet Aligned Resonance technology
  [獨有的"吊索懸浮承盤系統" - 隔振技術]
• D/A-Converter through USB/SPDIF digital input
  [能以 USB 端子連結電腦,成為外部音效解碼裝置]
• DSD/PCM-Converter
  [採用高效能 DSD/PCM 解碼晶片]
• Audionet Intelligent Sampling technolog
  [獨有的"智慧取樣"技術,去除時基誤差]
• Audionet or Lagrange filters selectable
  [Oversampling 的濾波器可切換選擇]
• Audionet HighBit-interface for all audio data, incl. DVD-A and SACD
  [特有的高速數位流傳輸介面技術,可數位輸出任何格式訊號予外部解碼器,
   包括 DVD-Audio 與 SACD 之數位訊號]
• Digital outputs can be turned off
  [數位輸出可關閉不用]
• EPS connection for providing analog-voltages
  [能外加接 EPS,將數位與類比電源 隔開供電,展現極致音色]
• Video
  [Progressive Scan 480P 循序掃描類比輸出]
  [HDMI 480P 數位影像輸出]
  [純聽音樂時,影像迴路可關閉不用]
一定争取拿下,呵呵
带视频的机器~~~
VIP G2
Function Universal playback system for CD, DVD and SACD
Laser system Semiconductor laser, 650 nm and 780 nm wavelength
Standards CD, CD-R, CD-RW
DVD-R, DVD+R, DVD-RW, DVD+RW
Video CD, Super VCD
DVD-Audio, DVD-Video
SACD Stereo and Multi-channel
Dolby Digital , DTS , DTS CD, MP3
PAL/ NTSC progressive
PAL/ NTSC interlaced
Converters Main channels
192 kHz/ 24 bit,
Multibit delta-sigma
Effect channels  96 kHz/ 24 bit,
Sampling rates 32 kHz, 44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz, 176.4 kHz, 192 kHz
Video six 12 bit video DAC, 16x oversampling, 216 MHz
Audio bandwidth max. 0 - 90 kHz (-3 dB)
THD + N Main channels
typ.116 dB (A weighted) @ -60dBFS
typ.102 dB (A weighted) @ 0dBFS
Effect channels
typ.95 dB (A weighted) @ -60dBFS
SNR 116 dB
Channel separation > 130 dB @ 10kHz
Audio outputs, analog 6 Cinch line, gold-plated
2 XLR symmetric, gold-plated
Audio outputs, digital 2 Cinch, 75 ohms, gold-plated
1 AES/EBU, 110 ohms, gold-plated
1 Audionet HighBit-DataLink
1 Optical (TOS Link)
Audio input, digital 1 USB, connected for USB-Audio and SPDIF (as computer's external sound card)
Video outputs, analog 1 YUV progressive/ RGB interlaced
1 S-Video
1 Composite-Video (CVBS/ Sync)
Video outputs, digital 1 HDMI 1.1 (DVI with HDCP compatible)
External power supply 5 pins precision connector
Output impedance
analog 33 Ohms real
Output voltage
analog 3.5 Veff
Mains 120 V, 60 Hz
Power dissipation 2 W Stand by, max. 50 W
Dimensions 430 mm * 110 mm * 360 mm (W * H * D)
Weight 22 kg
Finish Front brushed aluminum, black anodized, white printing or aluminum nature, anodized, black printing
Cover
Chassis
MDF, Nextel coated/ granite, steel, black coat
韩兄好象拿了一台SONY的SACD机,用下来如何啊?
加上EPS升级电源要7万大元!而且还要订货,据上海的林老板说他才订到两台,而且要到6月份才到货。
是好dd,可惜就是价格~~
东西8错
