谁可以介绍一下盟主的雷鸣吗?有具体的图片和资料吗? [复制链接]
查看: 2911|回复: 11
谢谢
DING
箱子我知道,图片倒是手头上没有,建议到盟主网站上找吧。
英文名字叫什么?谢谢
我是说箱子的英文名字?是AVATAR还是ARCUS?
ARCUS
Specifications
Driver Complement: 1" inverted dome Titanium tweeter
8" Nomex/Kevlar composite cone woofer
Impedance: 5 ohms nominal (4.5 ohms minimum)
Frequency Response: 45 Hz to 24 kHz (+/- 1.5 dB, anechoic)
(In room, -3dB point is below 35 Hz)
Recommended Power: 30 to 200 Watts
Dimensions: 37" high x 9 1/2" wide x 13" deep
Weight: 70 pounds (each)
顶
http://www.avalonacoustics.com/
信噪比 在 2004-11-24 16:07:06 发表的内容
应该是前者,书架箱子。
啊,不应该是书架箱吧。
AVATAR
The Avatar is a continuation of the Avalon Acoustics lineage of superlative sonics and elegant aesthetics. With its ability to provide superb imaging, transparency, and tonal balance with a wide variety of associated equipment, the Avatar provides an unprecedented level of sophistication and performance for smaller listening environments.
Specifications
Driver Complement: 1" Titanium dome tweeter
Sensitivity: 85dB (2.83V, 1M)
Impedance: 6 ohms nominal (5.5 ohms minimum)
System Resonance: Q = 0.5
Dimensions: 34" high x 9" wide x 13" deep
Weight: 65 pounds (each)
