ASCENDO [复制链接]
查看: 5629|回复: 31
德国的高级音响ASCENDO,是成立于1999年的高科技音响企业,装设可变时间微调机构的高级扬声器系统的制造和数码修正系统,还有室内音响测定等都是他们的主要业务。
[upload=jpg]Upload/2004111213184417709.jpg[/upload]
该公司推出的扬声器有4个系列:
System E
[upload=jpg]Upload/200411121332785313.jpg[/upload]
最后编辑masterbee
中高和低音分箱体是大势了
system K
[upload=jpg]Upload/2004111213123631285.jpg[/upload]
system M
[upload=jpg]Upload/2004111213402950609.jpg[/upload]
[upload=jpg]Upload/2004111213404034069.jpg[/upload]
[upload=jpg]Upload/2004111213371558446.jpg[/upload]
[upload=jpg]Upload/2004111213375533084.jpg[/upload]
system M-s
Technical Data
Principle:
three way SASB-technologie
(dynamic–current–damped woofer
and semisymmetrical bandpass)
Design:
modular:
discoupled mounting of speaker,
variable time–alignment for listening
positions between 50 and 190 cm
over floor
material:
stainless steel, low–resonance wood /
bitumen sandwich housing
Dimensions (B/H/T) :
Stand:
40 / 128,5 / 65 cm
Loudspeaker:
40 / 148,5 / 45 cm
Loudspeaker+Stand:
50 / 156,0 / 65 cm
Weight  :112 kg
Power :600 Watt program (min)
Impedance Ohm
Sensivity 8 dB / 1W/m
High–frequency–unit:
Speaker:
Ribbon-tweeter
impedance adjustable for
damping factor of power amp
Low–frequency–unit:
outer chassis:
21 cm chassis, HPC diaphragm, phase plug
inner chassis:
28 cm chassis, Hexacone
Adjustment for positioning  :switch able
Sockets  :Si / Bi / Tri–wiring
Finish :lacquer (standard), piano lacquer, veneer, custom made
最后编辑masterbee
[upload=jpg]Upload/2004111213151812198.jpg[/upload]
最后编辑masterbee
[upload=jpg]Upload/2004111213452622161.jpg[/upload]
[upload=jpg]Upload/2004111213464245738.jpg[/upload][upload=jpg]Upload/2004111213474546085.jpg[/upload]
中级别的SYSTEM K-S 在日本卖:3146000日元
[upload=jpg]Upload/2004111214294287549.jpg[/upload]
有无报价?
petershao 在 2004-11-12 13:07:54 发表的内容
是不是还有一种高音可以前后调整的?
全部都可以啊
