9NT音箱是什么牌子的?????????? [复制链接]
查看: 3106|回复: 8
看到论坛上有人提到他,有谁知道他是什么牌子的??有图片更好。 落地还是书架??  多少米??
B&W
[upload=jpg]uploadImages/2003513940479468.jpg[/upload]
美刀 2500
非常感谢两位DX得指教!!!!!!
喇叭單體 高音 1x25mm金屬振膜+導管
中音1x165mm防彈纖維
低音2x165mm 紙與防彈纖維
頻率範圍 -6dB at 30HZ and 30KHZ
頻率響應 38HZ - 25kHZ+-3dB
靈敏度 89dB
阻抗 8歐姆
分頻點 350HZ,4kHZ
建議功率 50W~200W
尺寸 高:1000mm
寬:220mm
深:315mm
重量 26.5Kg
外表顏色 紅木色,櫻桃木色
建議價格台币 $93,000元/對
HK$18,000
Description: 3-way vented-box system
- Frequency Response: 38Hz - 25kHz /-3dB on reference axis
- Frequency Range: -6dB at 30Hz and 30kHz
- Sensitivity: 89dB spl (2.83V 1m)
- Nominal Impedance: 8 ohms (minimum 3 ohms)
- Power Handling: 50 - 200W into 8 ohms on unclipped programme
- Drive Units: 1x 25mm (1in) metal dome high-frequency, 1x 150mm (6in) woven Kevlar cone FST midrange, 2x 165mm (6.5in) paper/Kevlar cone bass
- Finish Cabinet: Real wood veneers, Black Ash, Cherrywood, Red Cherrywood, Grille: Black cloth
- Harmonic distortion: 2nd and 3rd harmonics (90dB, 1m)
<1.0% 80Hz - 20kHz
<0.5% 150Hz - 20kHz
- Max. recommended cable impedance: 0.2 ohms
- Crossover frequencies: 350Hz and 4kHz
- Dimensions: 1000 x 220 x 315mm
- Weight: 26.5kg
B&W
B&W
b&W
