Jamo X3M10 [复制链接]
查看: 8725|回复: 32
请问各位前辈,Jamo  X3M10如何?
我想知道的不单是它的各种指标,外形尺寸。还有它适合听什么音乐,用什么功放(5000元以下)去推比较好,在哪里(广州)有的卖?
千万别笑我什么都不懂,我是刚出道的小妹妹,很想在买第一套音响之前学多一点。实在非常感谢!!!
Hamasaki 在 2003-3-5 16:42:37 发表的内容
那请问有没有窄身修长的音箱介绍,黑色的,喜欢低音喇叭在侧面的。谢谢!
在黄沙大道一中附近的“名石”音响有一款意大利“傲霸”落地箱,一只5”低音单元、一只1”球顶高音单元,窄而修长,样子好靓,非常衬靓女。也适合听弦乐和人声,用花梨木实木来做,做工很精细,灵敏度高,好容易推,接近黑色(红黑之间),售价4800元,我问他:为什么甘平,他答:1、是过去代理的品牌,现在只剩下一对,至在清货;2、音箱有划花少少(但我未看见)。
我认为:这对箱非常超值,你不仿去看看。
Hamasaki 在 2003-3-5 16:46:01 发表的内容
可以详细一点吗?什么牌子?型号?尺寸?其他指标?推荐的功放?万分感谢!!
还有,你的E-mail是什么,可以通E-mail吗?
[upload=jpg]uploadImages/20033516505968665.jpg[/upload][upload=jpg]uploadImages/20033516521470666.jpg[/upload]The 2.9 is a smaller version of the flagship 3.3. The 3.3's famous 12" woofer has been replaced with an equally astounding 10" unit, and the cabinet has been made slightly smaller. Otherwise, the designs are essentially identical. Like the 3.3, the 2.9 is a 4-way system, employing a 1" aluminum dome tweeter plus drivers for upper and lower midrange frequencies, along with an acoustic suspension side-loaded long throw woofer.
Specifications
System Type:
4-way, acoustic suspension
Drivers:
10" long-throw polypropylene subwoofer, 6.5" polypropylene lower midrange, 4" polypropylene uper midrange, 1" fluid-cooled aluminum dome tweeter
In-room Response:
26Hz -26KHz, +/-3dB
Sensitivity:
87dB SPL @2.83V/M
Impedance:
6 ohms nom., (3.1 min.)
Suggested Amp. Power:
30w/ch - 250w/ch
Dimensions:
39.5"H x 7"W x 21.5"D
Weight:
78 lbs. each
Finish:
High gloss black, mahongany or sycamore laminate
Following in the footsteps of our successful SuperZero and SuperOne loudspeakers, the SuperTwo is NHT's most affordable tower speaker, offering an unprecedented level of sonic refinement at its price. Employing the midrange and tweeter from the critically-acclaimed SuperOne, the SuperTwo adds a downward-firing subwoofer for truly full-range performance. This remarkable 6.5" woofer is capable of 14mm peak-to-peak excursion and delivers solid bass response to 35Hz.
Designed for discriminating audio/video enthusiasts, the SuperTwo is ideal for two-channel audiophile systems and five-channel home theater systems, where it is timbrally matched to the SuperZero and SuperOne. And its small footprint makes it a sensible choice when space is a prime consideration.
Specifications
System Type:
3-way, vented
Drivers:
6.5" long-throw subwoofer, 6.5" midwoofer, 1" fluid cooled soft dome tweeter (video shielded drivers)
Response:
35Hz-25KHz +/-3dB
Sensitivity:
87dB @ 2.83V/M
Impedance:
8 ohms nom.,(3.8 min.)
25w/ch - 175w/ch
Dimensions:
39"H x 7.25"W x 10"D
Weight:
39 lbs. each
Finish:
High-gloss black laminate
cartier@263.net
小姐,我发的都是抄的,用音乐传真,雅骏,AUDIOLAB都可以,看你的米咯。他们一般大概也是四,五千的样子。单元越多越贵咯。都是钢琴烤漆,靓。还有全白的合你哦!
我帮你打听一下价格,等消息,收站内短信
要是纯两声道,就选这几件功放,加喇叭,15000没问题,去买的时候打对折砍价,记住总代理最后去,那里是最便宜的,但一定要先多跑几家,摸个价。喇叭的水分比公房多!别让人看出你不懂哦?找阿泰或是ERIC陪你去咯,就是怕没人相信你是女的,呵呵,我再帮你问问。
[upload=jpg]uploadImages/2003369354910962.jpg[/upload]
SYNTER 200T喇叭  一万左右 阻抗:4 Ω
效率:90 db
尺寸:96 X 21 X 30 cm
重量:20 Kg
这对箱好难看的,不配你啊,小姐。
NHT!
