2。5万元可买世霸什么音箱? [复制链接]
查看: 2910|回复: 14
如上
我看世霸的东西买回家里即使不用,光放在那里看和摆设都行了。
还是买这款吧!http://www.aiyue.net/productShow.asp?id=145
happy 在 2004-2-3 21:58:58 发表的内容
masterbee 在 2004-2-3 20:28:33 发表的内容
Grand  Piano Home
大钢琴来了。
[upload=jpg]uploadImages/20042321583810613.jpg[/upload]
喇叭下加块4CM大理石,应该会更好:)
Grand  Piano Home
大钢琴来了。
哇太漂亮了,楼上的仁兄用什么搭配啊,播交响乐过关吗?
多谢了楼上的老兄,1。5万元左右有什么功放可推它吗?
System: Is there really no high pass in the crossover? Not even at the 3,000 Hz point for the tweeter
Cabinet: Construction with decoupled side panels for resonance control.
Mid-woofer: Sonus faber design, ultra dynamic linearity driver, 2 x 180 mm fiber glass multicoating cone, magnetically shielded.
Sensitivity:  90 dB/1W/1m.
Tweeter: Sonus faber design, neodymium ultra dynamic linearity driver, 26 mm silk dome ferrofluid, magnetically shield.
Cross over:  First order attenuated cross-point 200 Hz and 3,000 Hz. Impedance: 6 ohms nominal.
Power handling:  30/250 W, without clipping.
Frequency response:  35 - 20.000 Hz, tuning port included.
Finish: Combination of black leather and solid walnut or black piano lacquer.
Dimensions:  235 x 290 x 1080 mm (W D H) - 9 ¼ x 11 ½ x 42 ½ in. (W D H).
Weight:  50 Kg pair without packing - 58 Kg pair shipping weight.
http://www.excel-hifi.com/Sonus%20Faber/ex%20sf%20grand%20piano.htm
最好去实地听一下。
Grand  Piano Home
