米拉奇omni260搭配什么功放比较好? [复制链接]
查看: 2097|回复: 7
座地箱,25mm纯钛高音,6.5''中音及低音。RMS〉200瓦。
灵敏度高达93db。
有没有什么好的前后级推荐?
不会粗线条啊,反正你完全不用担心MIRAGE的低音就是了,A88T至少可以把喇叭推得比较充分了
最后编辑leslie
[upload=jpg]uploadImages/20041151554765325.jpg[/upload]
http://www.miragespeakers.com/omni260.shtml
Magnetically shielded 2 1/2-way tower speaker utilizing proprietary Omniguide technology with a 1" PTH tweeter and two 6 1/2 " polypropylene woofers. Available in black ash or cherry finish. Power handling of 200 watts RMS per channel. Connection via high quality 5 way binding post/terminals.
THE OMNI 260, the flagship of the new OMNI series is a quasi- three way speaker that utilizes the OMNIGUIDE module housing a 1" PTH- pure titanium hybrid tweeter suspended over a 6-1/2" titanium deposit driver. The entire module is situated on an angled platform at the top of the loudspeaker. Traditionally, Mirage has used speakers firing both out of the front and rear of the cabinet to create OMNIPOLAR sound dispersion, with OMNIGUIDE this is no longer necessary.
Each tower speaker is outfitted with 2 removable grills, one to hide the top OMNIGUIDE segment and another to conceal the front firing 6-1/2" titanium deposit driver and specially tuned flared port. The OMNI 260 uses 3/4" MDF for cabinet construction as well as high quality 5-way mounting terminals and tip reducing stabilizing legs with threaded spiked feet. The result is a much more refined and finished look of a traditional loudspeaker with unprecedented sound and performance that you have come to expect from Mirage.
The 260"s have an 8 ohm nominal impedance (4 ohm minimum) and have a frequency response that goes from 35Hz~20kHz +/- 3dB. Maximum power handling is rated at 200 Watts. Finishes include a choice of Black Ash or Cherry.
功放预算???合并可以吗?
师法自然乐器的发声原理─Mirage Omni 260喇叭/郭汉丞
音响论坛183期
最后编辑leslie
有机会希望能到贵府一叙!
我是指它的低音可以满足你的要求:)
艺术家10.0+8.0可以吗?看功率好像不够,JS也说用胆机的话可惜了omni的纯钛高音。而A88的高音似乎比较粗线条。没有听过,痛苦。
用V8I或胆机CAYIN A88T吧:)
“完全不用担心MIRAGE的低音就是了”
L版的意思是指低频驻波?偶的厅是个接近正方形,为此头疼不已,已经大兴土木做了许多处理,但是唯有形状是改不了了。
同在上海,谢谢L版指教!
先不过多考虑预算,大不了把本来花在AV系统上的先挪用过来,当然能省最好。260的参数我都有了,主要是考虑驻波,另外也喜欢他的音色。JS说一般国外的搭配是皇冠,但国内没箱子,所以也无从听起。
音响论坛的文章现在找不到啊!麻烦L版能给一份吗?
