转贴,看看美国家庭影院论坛上对惠威,B&W,MK的评价,简单翻译了一... [复制链接]
查看: 6312|回复: 11
http://www.hometheaterforum.com/htforum/index.php
靠,美国的烧友都很喜欢惠威的DIVA系列,评价极高,好多烧友居然把自己的什么 Paradigm等箱子,换成DIVA,SWAN的,和国内正好相反啊。。。奇怪,难道惠威在国外卖的是极品,在国内卖的是垃圾?值得思考。
I'm getting close to upgrading from my current Paradigm Monitor series speakers. How would the Swan's stand up against say the Paradigm Studio's or B&W's??
我近期准备升级我的PARADIGM监听系列喇叭,天鹅与PARADIGM和B&W比如何?
Yo. I can't comment on how they'd compare but I just just picked up Diva 6.1/C3/R3. My old speakers were klipsch RF3/RC3. The cabinets are beautiful & the sound is a big improvement.
至于对比,我不发表评论,我刚买了DIVA 6.1/C3/R3,我原来的箱子是 KLIPSCH RF3/RC3,现在的箱子非常漂亮而且声音好很多.
I have 4.1s and monitor 5s in my HT setup. The 4.1s have better sound to my ears than the monitor 5s. Tremendous bang for the buck IMO.
我有DIVA 4.1S 和 5S. DIVA 4.1S 声音听起来比5S好.
I have 4.1 mains, 2.1 surrounds, and a C3 center and love them. The black cherry finish make these speakers a steal, and I actually prefer it to the rosewood (blends ALOT better w/ silver/black TV and silver/black AV Stand). They still have the piano black top/bottom and the sound is exactly the same. My las speakers were Paradigm 5SE MK3s (predecessor to current monitors) and it was a big improvement w/ a slight loss in bass (AV12 sub takes over below 80hz so that didn't bother me). The 6.1s should be amazing even without a sub.
我的主箱是DIVA 4.1 ,环绕是DIVA 2.1, 中置C3,.......在此之前,我最后的系统是PARADIGM 5SE MK3S, 现在声音提高很多,.低频差点(但是,我的AV12 低音炮发出80HZ以下的声音,这个问题解决了).....如果没有低音炮,DIVA 6.1S的表现应该应该是很好的
Good input people. Thanks!!
深入人心啊,,谢谢...
http://www.theaudioinsider.com/
"...very musical speakers...superb quality of construction and outstanding sound..."
Ric Siegert, Stereotimes
"...the overall best sounding speakers we've reviewed."
Cheap Home Theater.com
"These are the clearest speakers I have ever heard. These speakers totally rock."
J. Berning, ReviewBoard.com
"You won't believe what you will get with the Diva by Swans speakers...an unbelievable value"
John E. Johnson, Secrets of Home Theater & High Fidelity
Prices for the new 700 series (european price for 1 pair):
705 (replaces CDM-1NT => €1400
704 (replaces CDM-7NT) => €2200
703 (replaces CDM-9NT) => €3000
HTM7 (replaces CDM-CNT) => €750 (1 piece)
ASW-700 (new subwoofer) => €1500
ASW-750 (replaces ASW-CDM) => €1800
DS7 (dipole surround speaker) => €1400
About 10% more expensive than the CDM NT series.
B&W 新的700系列的价格(欧元/对),大约比CDM NT系列贵10%, 靠,仅贵10%???国内销售报价好象要贵50%似的?
小杜 在 2003-11-11 23:40:30 发表的内容
深入人心啊,,谢谢...
我曾问过一位发烧店老板.他说,惠威本身很好,但国内的就不跟卖在国外的.不知对不对.
Local salesman said he could sell me the following:
4 CDM1NT"s (2 fronts-2 rears)
1 CDMCNT (center)
all for $2400+tax
will I get good surround sound with the cdm's against the back wall? My listening area is also against the back wall, I may be able to pull it out 12-18 inches.
本地销售商报价如下: 4只 CDM 1NT (2前2后), 1只CDM CNT (中置),全部2400美圆再加税, 如果CDM 放在后墙,能获得好的环绕效果嘛? 我的听音区也靠后墙,我可能需要将箱子外移12-16英寸.
If you listened to the speakers and like them, then get them. B&W is closing out the CDM line in favor of the 700 line. The 700s are now posted on B&W's web site. I believe the 1NTs list for about $1,200, the CDMNT around $600. Normally, purchasing that much equipment, you can work the dealer for 10-15 percent off list. The dealer obviously is trying to close out whatever stock is left.
The 1NTs are fine speakers. Matched with a good sub and capable electronics, you should be OK. Try to give the speakers at least 18 inches from the wall.
如果你听过而且喜欢,那就买吧,B&W很快要停产CDM系列了,取而代之的是700系列,700系列现在在B&W的网站上有了,1NT报价单上是1200美圆,CNT是600美圆,一般来说,购买这些产品,你可以砍价10%-15%,经销商显然在清库存.
NT系列是很好的箱子,配个好点的炮和合适的功放,可以获得很好的效果,试试将箱子离墙至少18英寸.
Might want to give the Swan Diva line from www.theaudioinsider.com a try. The Swan's Diva's have been compared VERY favorably to the B&W Nautalis series in both fit and finish. You could get 4 2.1s and a C3 for under $1k in the Black Cherry finish. If you like the Rosewood finish you could step up to that, or put your money in better mains. For $2400 you could have 2 pairs of 6.1s and a C3 including shipping.
你可以试试从WWW.theaudioinsider.com 购买天鹅DIVA系列,天鹅DIVA 系列不管从表现还是外观,都可以与B&W 鹦鹉螺系列一拼,你可以以不到1000美圆的价格买DIVA 2.1S 4只 和C3(黑樱桃木外观), 如果你喜欢玫瑰木色的,也可以选用,或者将你可以选择更好的主箱,2400美圆可以选择两对DIVA 6.1S和C3中置,还包括运费..
这就不知了.但我想B&W等国内和国外有差距,
国内的要好过国外的?
要不怎么比国外的贵?
谁解释?
那就是B&W的国内和国外有差距,国内的要好过国外的?
该用户帖子内容已被屏蔽
如果听音取向不一样,为什么老外调出来的声音我们也同样叫好呢?这里有谁说英国声不好的吗?
阿龙 在 2003-11-12 16:24:04 发表的内容
我问过惠威的销售主管,
回答是,国内国外一个质量,并没有出过两个版。(换句话说,要真有两个版,且质量差得那么大,我早就有办法把国外版搞到手了。)
m1有出口版,单元是第一批配对的喇叭,第二批配对做成国内版,第三批做套件。这里的经销曾向姚洪波进了两对出口版的m1,一对在我同学那里,另一对他自己留了。价格与国内版一样。原来在网上见过黑色钢琴漆的m1出口版,但问了后说没有产过?
