初哥紧急求教!天朗“超感官”配什么功放? [复制链接]
查看: 3091|回复: 9
我想配一套家庭影院,主要用作看DVD和听轻音乐、唱歌、古典影院,不会听Disco一类比较吵的音乐。
现基本选定了天朗“超感官”系列音箱:
主音箱:DC2 落地箱一对
环绕音箱:DC1 书架箱一对
中置:DCC 一只
总价格:17400元
我看中的主要是这个系列音箱的同轴和超高频!各位DX对此系列音箱是否了解,可否指点一二?
现在困扰我的是功放,商家给我推荐了以下2款功放:
1. 天龙1803 3700
2.马兰士5300OSE 3900
我对功放的预算是6000以内,要求有DTS96/24,最好有THX,这两款好像都不行,但是他们更高的型号好像可以。希望给我DX给我推荐合适、匹配的功放!
另外,j这里的价格是s给我的底价,各位觉得如何?
这是xd初次发贴,万望各位DX指教!谢谢!
那只有安桥的TX-SR701
northSound 在 2003-10-15 16:38:31 发表的内容
那只有安桥的TX-SR701
谢谢northSound !我也相中了SR701,不过JS对它的评价不高,说不如天龙和马兰士的,所以还没有拿定主意。你给我的意见非常重要!
安桥的TX-SR701是6.1声道的,最好再配一个DCC做后中置,
播DTS ES.Discreter/dobly ES软件回有提升的.
DC主落地箱根本达不到THX的重播要求,建议加个LEF.
两款公房中,天龙较合适。
northSound 在 2003-10-16 0:28:39 发表的内容
初级问题:THX对主音箱的要求是什么?LEF是什么?
不好意思,谢谢!:)
本人听过用30W和15W胆推的超感官系列~
解析力一样非常的好,而且声音很随和~
我个人比较喜欢~不张扬的声音~
Front Channel Loudspeakers
Front channel imaging is also extremely important in producing accurate sound. For films, the sound has to match the picture perfectly. Conventional two-channel speaker designs are constructed to present a good solid image over a 45 to 60 degree angle. If you spread the speakers too far apart, you get a hole in the center image. Place them too close together, and the sound stage collapses into a fuzzy mono sound. In a multi-channel sound system, sound images are formed between Left and Center and Right and Center Speakers. This means that speakers must be precise enough in their imaging characteristics to create a sound stage over half the separation distance normally expected for a two-channel system.
Home THX LCR front channel speakers improve dialogue intelligibility and imaging in two ways. First, they provide wide horizontal dispersion. This allows for people sitting off-axis to hear full and flat frequency response. The second technique is to control the speakers' vertical dispersion. Acousticians have found that the ceiling and floor reflections deteriorate a speaker's ability to image. In addition, the coloration from these vertical reflections cloud intelligibility.
Surround Channel Loudspeakers
The purpose of a surround channel is to surround you with sound. The problem is that this is tough to do with just two speakers. Decorrelation takes care of Left/Right spaciousness, but what about wrap around envelopment? If a director chooses to place you in a wind storm, conventional speakers leave you with the impression that you're hearing the windstorm through two open windows.
The Home THX Diffuse Surround Speaker is designed to provide a "movie without walls" experience. It does this by painting the walls and the ceiling with sound. It sends very little sound towards the listener. The sound reflecting off the room’s walls and ceiling provides an enveloping soundfield, immersing the listener in the movie experience.
The total energy radiated by a speaker in all directions is called its "Power Response". The Home THX Diffuse Surround Speaker is required to have a flat power response. This means that the total energy radiated by the speaker (in front, above, below, behind, and to the sides) must together average a flat frequency response. With the total speaker energy being flat, a listener anywhere within the surround speaker's null area will hear flat frequency response.
Subwoofer Loudspeakers
The final requirement for accurate multi-channel sound reproduction is accurate deep bass response. All THX subwoofers are designed to precisely match LCR speakers through the Electronic Crossover in a Home THX Controller or Receiver. THX Subwoofers must have an accurate in-room response down to 20 Hz. Approved systems must be able to play 105 dB sound pressure level or louder without distortion. THX subwoofers come in a variety of configurations and can be use singly or in multiples to match the requirements of even the largest listening room.
form  http://www.thx.com/mod/techlib/speakers.html
LFE: 低频信号   可通过增加重低音解决,标准上文Subwoofer Loudspeakers 讲的很清楚.
YAMAHA Z1
