请问音箱需要煲多长时间?1000小时够吗? [复制链接]
查看: 2310|回复: 3
另外喇叭线,信号线呢?我的城堡EDEN已经煲了有近1千小时了,不知是否进入状态?我现有天龙CD机,想用JOLIDA 300B 或者用707A  6P3P推挽的胆机推EDEN,不知如何?我看上了300B单端的,我主要听古典音乐为主,面积15平方,以后当然要把CD机换掉!请教各位还有什么更好的搭配?我喜欢耐听的,圆润的声音!谢谢各位!!!
看是什么音箱吧,难煲的音箱要过1000小时的,至于你的城堡,1000小时足够了。
CASTLE 在 2004-3-29 16:32:50 发表的内容
一般200小时就足够了。
配城堡的音箱一般功放的功率要大些,否则会感到声音有气无力。
If your amplifier cannot supply full range spectrum, then
10,000 playing hour cannot aging the speaker.
The speakers more or less like human being, you have to feed
them with good food ( nutrient ).
Full spectrum, for example from low to high with sufficient
harmonics will breakthrough all the parts including the voice
coil and the cone into the state of  mature.
With good amp system (including good sound source such as
CD player), your speaker will go into mature state.
