L板能找到 [复制链接]
查看: 2574|回复: 7
Conrad-Johnson12后级的介吗,谢!
谢!
Premier Twelve & Twelve-XS Vacuum Tube Power Amplifier
Introduced in October 1993, Twelve XS in June 1995
The Premier Twelve is a mono-block tube power amplifier, in effect a smaller, lower powered version of the Premier Eight. It uses two pair of 6550s to produce 140 watts. It is similar in size and circuit to the stereo Premier Eleven. The Twelve-XS is a Twelve with the output stage configured to use a pair of EL34s operated as triodes to produce about 60 watts.
The Premier Twelve used only the finest component parts in all stages including the power supply. The power supply used only polypropylene and "cjd" polystyrene capacitors as opposed to the traditional deployment of electrolytics. The main storage reservoir used polypropylene capacitors with polystyrene shunts.
Features:
5-way binding post speaker connectors, one input, supply fuses, power switch
V1: 5751
V2 & V3: 6FQ7/6CG7
V4 ­ V7 6550 Premier Twelve
V4 ­ V7 EL34 Premier Twelve-XS
Replacement Tube Sets: RTPR12 or RTPR12XS
Click above for technical info on this product or to purchase a replacement tube kit.
Specifications:
Power Output: Ultralinear Operation: 140 watts per channel RMS at 4, 8, or16 ohms both channels driven from 30Hz to 15kHz with no more than 1% THD or IMD.
Power Output: Triode Operation: 60 watts per channel RMS at 4, 8, or16 ohms both channels driven from 30Hz to 15kHz with no more than 1.5% THD or IMD.
Input Sensitivity: 0.90 volts to full power
Hum & Noise: 98dB below full power
Input Impedance: 100K ohms
Mechanical: chassis 17 W" x 7 H" x 15 D"
Weight: 51 lbs.
[upload=jpg]uploadImages/20037151045682902.jpg[/upload]
Conrad Johnson 詩醉
產 品 型 號 :  Premier 12
產 品 名 稱 :  功率放大器
產 品 詳 情 : 產 品 詳 情 : 雙單聲道真空管功率放大器
靈敏度:0.9Vrms
頻率響應:20Hz至20KHz +/- 1db
訊噪比:98db
輸入阻抗:100K歐姆
輸出功率:140瓦
真空管:1支5751、2支6FQ7、4支6550 (每邊聲道)
尺吋:38.7cm x 44.5cm x 18.4Cm (深x寬x高)
重量:23.182公斤
產 品 價 值: HK$96,000
[upload=jpg]uploadImages/20037151032046968.jpg[/upload]
够了吗?不谢
有好多我找不到的,可别考我,我要糊咯。
依我看,CAV飞扬系列的评价他就找不到。哈哈
没有难得倒L版的!
