那位知道Harman Kardon AVR 10 这款功放? [复制链接]
查看: 2145|回复: 1
RT,能不能简单介绍一下
2手港币1000,
I use this reciever primarily as an amp for my CD player. After the initial purchase, I was greatly impressed with the overall sound, which you can read about in the other reviews. Then I spent some time with the surround sound, and found that it muted & distorted so bad that I eventually quit using it. After about a year, it began that unnerving buzzing while in standby, which seems to be a common problem for this model judging by the other reviews. Assuming either EMI susceptibility or Ground Plane Ref. Noise issues, I tried some selective wire routing, case grounding, internal cleaning, & eventually the problem went away. The speaker jacks are very cramped & don't take well to monster cable. I suspect that a few loose wirestrands from cable where costing me some performance issues. Also, the seek function on the tuner is worthless, which wouldn't be very significant given the fact that you can program 29 presets, except for the fact that the memory clears whenever the power goes !!! So you find yourself reprogramming the presets more than you'd like, which brings me to another aspect of the design philosophy that peeves me a bit... you're dependant on the remote for programming your presets... and if that's the only thing you use your remote for (like me) than you also tend to misplace the darn thing... I'd rate it lower, but the overall sound is nice & counts for a lot... If I were to redesign it, I'd rip out the surround sound and put the money into static memory, EMI imunity, and spreading out the jacks.
Strengths:
Nice sound
Weaknesses:
Poor tuner seeking, loss of presets when power is off, week surround sound, cramped jacks,
Product Model Year:
1998
Summary:
This is one of the best receivers for the money. Very natural sound,tight bass,non intruding highs. I'm running Yamaha 6390's in front,the sound is exceptional. Also, this is a sturdy machine. The right channel went out for awhile,so I used a PerfectDuster to blow away all the dust that accumulated inside,and presto!! the channel is back!!! So a word to the wise: some problems can be fixed just by doing a cleaning of the interior. You don't even have to open the chassis,just spray the air through the vents.
Strengths:
Good Pro-Logic
Weaknesses:
Back Panel design too cluttered
Product Model Year:
1998
Summary:
Bought this receiver "as is" from ubid.com for $39 plus S/H. I'm currently using it as my bedroom system.
I was first introduced to HK in college when my room-mate brought back an HK stereo receiver after X-mas break. The sound was incredible. Elements of music that I couldn't hear through receivers by Kenwood or Sony were vividly and effortlessly reproduced by the HK.
The high-current of the HK amp's makes all the difference in the world. Solid craftsmanship from a reliable company.
I'm now a proud owner of several HK receivers and CD players, along with other products from Harman International (JBL, Infiniti).
My bedroom setup:
HK AVR10 A/V receiver
HK FL8550 CD player
Infiniti IL10 speakers
Monster Cable interconnects
10 gauge speaker wire (NOTE: HK recommends minimum speaker wire gauge of 12--this is to ensure proper transfer of current from amp to speakers)
Monster Cable Quick Lock terminators
I'm giving this unit 5 stars overall, since I paid less than $80 for the unit + S/H over 2 years ago, and it still works flawlessly.
Strengths:
Clean sound, banana plug compatible speaker posts, high current, simple front panel, plenty of power for small room
Weaknesses:
No speaker set B outputs, no spade compatible speaker posts
Price Paid: $135 at eBay
Product Model Year:
1999
Summary:
Let me say that I was very skeptical of what I would get for a paltry $130. Wow! What a suprise!
The AVR-10 does just a good of a job as filling my guestroom with clean, warm and accurate sound as my $1000+ Adcom system. However, my Adcom kicks ars in a bigger room.
The AVR-10 is solid, elegant and packed with enough features to handle the job of providing outstanding sound and quality home-theatre-experience to a mid-size room.
The AVR-10 looks great too. For the money, I have to give it a 5.
Strengths:
Great sound, good looks and plenty of features.
Weaknesses:
Don't expect it to blow away a 40 x 40 room. One of the owners of HK is commi-liberal politician Jane Harman. ;)
2手在45美金——135美金之间
如果你以他为主力解码的话,那么还是忘记它吧
最后编辑leslie
