音箱和功放的花费是否真的是1:2 [复制链接]
查看: 3975|回复: 6
[upload=jpg]uploadImages/2003424543727551.jpg[/upload]
朋友送我一对B&W DM601 S3书架式音箱,但是我对怎样配功放不太了解.有两个朋友行家建议我买一个比这对音箱贵的功放推才能发挥出最佳效果,花费比例在1:2(音箱:功放)左右.我这对音箱的参数细看了一下,感觉对功放要求不是特别高,配便宜的功放应该也能推的动.是否功放真的要买贵一点的.大家有无这样的感觉?下面是这对音箱的具体参数.请大家提出建议该配什么样的功放好.
Technical Specifications : DM601 S3
Description 2-way vented-box system
Dimensions Height: 365mm (14.4in)
Width: 204mm (8in)
Depth: 228mm (9in)
Net Weight 6.1kg / 13.4lb
Freq. Response 60Hz - 22kHz ± 3dB on reference axis
Freq. Range -6dB at 48Hz and 42kHz
Sensitivity 88dB spl (2.83V, 1m)
Nominal Impedance 8 ohms (minimum 3.0 ohms)
Power Handling 25W - 100W into 8 ohms on unclipped programme
Drive Units Unit 1: 1x 25mm (1in) metal dome high-frequency
Unit 2: 1x 165mm (6.5in) woven Kevlar® cone bass/midrange
Unit 3:
Finish Cabinet: Black Ash or Sorrento (light oak) vinyl
Grille: Black Cloth
Dispersion Description: Within 2dB of response on reference axis
Horizontal: over 40° arc
Vertical: over 10° arc
Harmonic Distortion 2nd & 3rd harmonics <1% 88Hz - 20kHz (90dB spl, 1m)
Crossover Frequency 4kHz
Cable Impedance 0.1 ohms
我也很想知道,怎么没有人指教?
我的是
2:1
这么肯定?
功放一般是越贵越好的,看你花费预算了。总是在同价位的东西里调最配的。
2000的功放配什么箱子?
3W以下的音箱高,以上的功放高
