有人知道SKYLAN这个加拿大脚架吗? 据说是雨后老板钦点的脚架品... [复制链接]
查看: 16927|回复: 28
打开雨后初晴英国的网站,进入FAQ列表(http://www.harbeth.co.uk/uk/index.php?section=products&page=faq),可以看到雨后老板关于音箱脚架的一段建议:
What type of speaker stands should I use?All Harbeth speakers need to be lifted off the floor and to an operational height by placing them on some sort of stand. None of our speakers will work correctly on shelves or close to nearby surfaces because the sound waves generated by the speakers will be acoustically coupled to (or trapped by) those surfaces, and re-radiated into the room. This will disturb our intended frequency balance of the speakers especially at low and middle frequencies where the speaker is omni directional.
It's important to know what we use when designing and measuring our speakers. To achieve a quasi-anechoic measurement of the speaker (i.e. one which is as little influenced by the local acoustic environment as possible) we elevate the speaker high above the ground on a single thin pole. This provides as much air around the speaker as possible.
There are many views about the materials from which the stands are fabricated - which could include steel, plastic or wood, as to whether tubular sections should be filled with sand or lead shot whether the stand should be an open-frame or a more enclosed structure. In our opinion, the primary matter is one of safety: whatever stand you select must be stable and must prevent the speaker toppling over, especially when there are children at home. Following that, we would put the height as the next most important factor: getting the speakers as high off the floor as possible and so that your ear is level with the tweeteroptimises your listening experience. As for solid or lightweight construction, both approaches have merit depending on whether one wants to contrast the thin-wall cabinet system or to compliment it. We recommend Skylan stands from Canada. Good stands. Friendly people to deal with. You could of course try an make your own, in which case a little detective work as to the optimim height, construction etc. may well be advisable.
As for spikes - we go to a great deal of trouble to ensure that the cabinets are perfect, and it never feels quite right to see that spikes between the top of the stand and the underside of the cabinet have punctured the veneer. A small ball of Blue-Tak (or similar) seems a much more elegant solution, but you should experiment. What matters is what sounds best to you. Please read the User Guide on the important subject of stands. To repeat: your stands must be stable.
其中有一段:“We recommend Skylan stands from Canada. Good stands. Friendly people to deal with. ”
本人笨拙翻译:“我们推荐加拿大的Skylan脚架,好脚架。老板人是个非常值得打交道的人。”
有个朋友想买雨后的C7,正发愁配脚架,但是SA的脚架太贵,对国产脚架又不太放心,听说这个脚架比较轻,不知道是什么材质,有人知道吗?
最后编辑sprs 最后编辑于 2014-11-18 21:13:06
宋兄推荐的东西,不会错了。
非常超值的脚架
呵呵,鄙人正在使用skylan这个牌子的雨后shl5专用脚架,是雨后标配脚架,国外用家很多,甚至多过米国SA脚架,在国内用家极少,不敢说是第一个吃螃蟹的人,但至少在雨后初晴音响群里是头一份。哈哈,脚架四柱,柱子里面是空的,可以灌砂、铅、铁砂等,根据不同喜好可以玩出很好的效果。该厂家也配有专门灌注的铁砂等材料,直接购进省事,但可玩性降低了。
回复 3# wzg147258369 的帖子
tnnd,发布了图片,上个网址,喜欢的骚人去看看:http://www.skylanstands.com/stands.htm,,,有同好者欢迎交流。。。群号62415598
回复 1# sprs 的帖子
回LZ,材质肯定不是钢或铁,主要材质猜测是塑钢一类的,标配圆钉和尖钉两种脚钉,尖钉低频清晰些,圆钉厚润点。
对了,忘记说了,skylan脚架国内没有代理,很是遗憾,我搞的这对脚架大费周章,与原来的贵族脚架PK后,贵族脚架直接扔墙角当花盆架了,死重的东西。
关注中,因为我们目前推出的全是书架箱,脚架是很关键的一环。
理智发烧,杜绝忽悠
原帖由 wzg147258369 于 2014-11-18 21:36:00 发表
谢谢,有了您的使用感受,我就放心帮我朋友买这个脚架了。我加拿大那边还是有几个朋友的,甚至可以让V-cap老板亲自帮我去搞这个脚架。
原帖由 潘志强 于 2014-11-18 22:04:00 发表
我看这个脚架的官网,貌似都是为雨后的音箱设计的脚架尺寸,不知道Opus1和Opus3可以使用雨后哪一款音箱的脚架
原帖由 sprs 于 2014-11-18 22:10:00 发表
估计适合HL5的,Opus 3能用?
理智发烧,杜绝忽悠
他们的产品大概是什么价格的?harbeth老板10多年前和我email也说过他喜欢用胆机推他的产品,晶体管机就推荐quad,现在不知道还是这样说吗?
最后编辑kkhuang 最后编辑于 2014-11-18 22:22:19
用过,品尝过的才敢叫好!
