美国PBN AUDIO 音箱介绍 [复制链接]
查看: 24026|回复: 33
一,Hadley Center
三分频设计,高音:Dynaudio T330D,中音:6寸纸盆,低音:双10寸。
jpg(2016/2/3 16:12:59 上传)
最后编辑北京飞韵美 最后编辑于 2016-06-17 19:39:38
www.fymhifi.com
二:Hadley
  • Frequency response  27 Hz to 22kHz +/- 3dB
  • Crossover points 200HZ and 3 kHz @ 24dB Octave
  • Impedance Nominal 4 Ohms (Min 3 Ohm Max 9 Ohm)
  • Power Handling 300W
  • Size: 44.5 H x 20.5 D x 16.25 W
  • Weight: 238 Lbs
  • Finish: Custom order (Finishes Charts)
jpg(2016/2/3 16:16:28 上传)
www.fymhifi.com
三:Pennywise Series
jpg(2016/2/3 16:21:08 上传)
www.fymhifi.com
四:B471
jpg(2016/2/3 16:24:01 上传)
gif(2016/2/3 16:24:01 上传)
www.fymhifi.com
五:XmaX
jpg(2016/2/3 16:27:47 上传)
www.fymhifi.com
六:Dayton Audio Xenia
  • Low-Frequency: 6 x 7” (Triple Compound) (Dayton Audio ES180Ti-8)
  • Mid-Frequency: 2 x 5” (Dayton Audio ES140Ti-8)
  • High-Frequency: 1x1” (Dayton Audio ES25Nd-4)
  • Sensitivity: 87dB/2.83V/1M
  • Crossover points: 200 Hz and 2kHz @ 24/dB Oct LR
  • Impedance: nominal 4 Ohms (Min. 2.6 Ohms, Max. 8 Ohms)
  • Dimensions: 13.5”W x 14.5”D x 48.5”H
  • Weight: 122 lbs
jpg(2016/2/3 16:31:23 上传)
www.fymhifi.com
七:SPC-2中置
  • Dimensions (HxWxD): 10.5" x 29" x 14"
  • Weight: 70 lbs
  • Frequency range: 40 - 30k Hz ± 1.5 dB
  • Finish: Custom order (Finishes Charts)C
jpg(2016/2/3 16:37:08 上传)
www.fymhifi.com
八:Mini MonitorTECHNICAL FEATURES
  • One 5.25” coated pulp cone mid-woofer with extremley smooth frequency response and one 1” tweeter
  • Internal custom-made crossover
  • Optional custom-made stand available
SPECIFICATIONS
  • Dimensions (HxWxD): 14 x 10 x 11
  • Weight : 25 lbs each
jpg(2016/2/3 16:39:26 上传)
www.fymhifi.com
九:Monitor M2TECHNICAL FEATURES
  • One 7” Vifa™ coated pulp cone mid-woofer with extremely smooth frequency response and one 1” SB Acoustics™ tweeter
  • Choice of fine real-wood veneers or piano lacquer finish
SPECIFICATIONS
  • Dimensions (HxWxD): 18" x 12" x 13"
  • Weight: 35 lbs each
jpg(2016/2/3 16:41:06 上传)
www.fymhifi.com
全英文?看不懂啊!
