正在试听的focal 专业数字监听喇叭SM11 [复制链接]
查看: 20020|回复: 28
Specifications
Frequency response :
34Hz - 40kHz (+/-2dB)
Maximum SPL :
118dB SPL (peak @ 1m)
Analog input :
Type/Impedance: symmetrical/10 kOhms
Connector: XLR
Sensitivity: Adjustable
A/D convertors: 24 bit resolution, 96kHz sampling frequency
Digital input :
Size: AES (110 Ohms with transformer)
Connector: XLR
Sampling frequency: 44.1, 48, 88.2, or 96kHz (automatic detection)
Signal internal treatment :
Audio processing: internal digital signal processor
N/A converter: 24 bit resolution, 96kHz sampling frequency
Dynamic range :
110dB
Bass amplification :
D class/250W rms
Mid-range amplification :
D class/150W rms
treble amplification :
AB class/100W rms
Control system :
Connection types: RS-232 series infrared (PC/Mac) MIDI
Electric supply :
Local supply power: 230V (3.15A fuses) - 115V (6.3A fuse) IEC local supply wire
Material functions :
Analog input sensitivity selector
AES left/right channel selector
Control interface selector
Software functions :
Sound level, "Sweet spot", "Shielving" EQ, equalizer, pre-selection, delays.
indicators :
Power on LED, infrared reception LED
Bass transducers :
Focal "W" cone 27cm speaker, 11W5511B long throw
Passive radiator :
Focal "W" cone 27cm passive radiator, 11WPP51 large surround
Mid-range transducers :
Focal "W" cone 16.5cm speaker, 6W0451 "push-pull" Neodymium magnet
treble transducers :
Focal pure Beryllium dome tweeter, TBU SM11 Focus Ring magnet
Shielding :
Complete with the magnet structure natural protection
Box :
19mm and 25mm MDF panels with internal reinforcements
Finish :
Slate grey metallic lacquer side panels
Dark red veneering top and bottom panels
Tinted solid wood sides
Dimensions (HxWxD) :
338x460x350mm
Net weight :
25kg
了解最新的音响唱片资讯请关注www.hifi168.com
该音箱拥有FOCAL最顶的铍膜高音单元,W音圈的中低音与低音单元,每一只的内置功率放大器合计达到500W。
低音为D类的250瓦,中低音为D类150W,高音为AB类的100W。
初步听感,该箱很能爆。两端的延伸和分析力都有不俗表现。
这喇叭没有听过,等听感
好东西总听不完。。。。。。。。。
CLK发烧电源排插、信号线!
目前只是在使用这对音箱的模拟部分,里面的数码部分等待发掘,通过AES接口输入可以最高支持到24/96的采样频率。
名品,等听感。
最后编辑KEN 最后编辑于 2011-04-25 20:08:56
原帖由 KEN 于 2011-4-25 19:07:00 发表有没有帮我听这个:http://110ken.blog.163.com/blog/static/56193455201122483356867/
还未安排到!明天来先听听这个吧!
该用户帖子内容已被屏蔽
孤独人@流浪  远方钢青色的天际线是我永恒而无法企及的追寻
