老夫倾家荡产,就是为了这个庞然淫物! Viva + Basis 2001黑胶(... [复制链接]
查看: 30344|回复: 62
这个周末再次对家里客厅的系统进行了调整。原因是在网上看到有人要出一个我多年梦想的合并机。这个牌子产量少,2手交易的更是前所未闻。我就立刻下手了。9成新!先卖个关子,有没有人知道型号和品牌?意大利的牌子。。。明天上客厅器材的全家福。今天先看卖家在网上贴的照片。。。猜猜!
最后编辑j_walk 最后编辑于 2009-06-04 09:15:23
果然没见过 看上去很敦实
庞然淫物!哈哈
音 源:XDK-MUSE Deluxe 1.0 +DAC-8+PC
前 级:G&W T-6S收藏版
后 级:G&W TW-A100订制版
音 箱: Dynaudio Contour S3.4
其 它:PS AC-12 、OCOS、XLO、FA-Gold 、FA-2、FP-1、FP-5、XF2000S滤波电源、西门子漏保、超级紫铜座、海阳二号钉.......
好东西!未见过,开估喇?
应该是845单端作功率输出的吧?
真不知是啥牌
外形漂亮
VIVA Solista LT Tube amp
The Little Solista, or Solista LT, is a physically smaller, less powerful version of the Viva Solista integrated. It cost $7600 with the remote, although I hear the prices are going up. What else is new. The (big) Solista is now up from $10K to about $17K, although I hear it is significantly different from what it was. The LT uses (2) 845 tubes, (2) 5u4’s as rectifiers, (1) 6922 and (1) 6SN7. It is approximately 18” x 14”, so it will fit in most equipment racks, although you are going to need some space above it to accommodate the heat of the 845’s. I use a Salamander rack, so I can adjust the height, but I have found that a small Vornado Zippi fan placed to the side of the LT, silently blows the heat out of the rack and keeps the shelf above the amp reasonably cool.
The styling from the “love it or hate it school” and it is available in a variety of automotive colors for a $300 upcharge. I opted for the standard dark grey/light grey, which looks great and costs nothing additional. The rear has standard binding posts, 4 sets of RCA inputs, a “direct” input for a preamp, and stereo RCA sub outputs. Nice touch. Power output is rated at 18 watts of SET power.
The sound was somewhat variable during the first month, but it settled down pretty quick. It seems consistent after 2 months use of about 10 hours a week, although I’m sure it has more to go. Before going into the sound, I think it’s important that I describe my listening tastes and expectations, as yours may vary. I live in a pretty cluttered apartment. My speakers flank the TV and audio rack and are about 18” out from the wall. The speakers are about 7’-8’ apart and I sit on a couch against the rear wall, about 8’ from the speakers.
I pretty much listen at night at fairly low levels. I prefer simple acoustic music – guitar/bass, piano/bass, piano/vocals, Bill Evans, Blue Note stuff. My speakers are the Opera Callas Monitors, which I switch off with a pair of Fritz 6.5” Fostex speakers when I feel like something different. Sources are vinyl, CD and SACD players.
The combination of the Viva with the Operas is just stunning. While the Operas are rated at 87db, they are an excellent match for the Viva. At low levels, the sound is very full, with a palpable sense of being there. One thing I could never achieve in the past was a real “soundstage”, which I assumed was due to having the TV and audio rack between the speakers. However, the Viva just tears down the walls and presents the performers on the stage in front of you. It’s as if there’s a large empty space between the speakers, not the actual clutter that exists. For me, this is incredible, as I thought I could never obtain this sense of space in my apartment. The second thing the Viva does well is the realistic presentation of instruments. I was a professional musician for 20 years and I am intimately familiar with how acoustic instruments actually sound. With a good recording, the Viva is capable of extracting the true timber of the instruments, bringing them into the room with you.
With the Fritz single-driver speakers, rated 94db, the Viva is extremely quiet. The sound is very complete with an addictive coherence that eludes most multiple-driver speakers. While they don’t have the bass of the Operas, the sound is still very enjoyable due to the clarity and quick transient response. The light Fostex cones react much faster than the Scanspeak drivers in the Operas, although I don’t think I would want to live with them permanently. It’s nice to go back and forth between the two speakers.
I think the Solista LT would make an excellent choice for anyone who values tone over volume and can live with the physical size and looks of the unit. For an apartment dweller like me, the LT has been a revelation in bringing the sound of live music into my small space.
jpg(2009/5/17 16:43:19 上传)
jpg(2009/5/17 16:46:36 上传)
最后编辑leslie 最后编辑于 2009-05-17 16:46:36
真靓,口水.
So it goes with the Solista, which carries on the Viva tradition in every way: single-ended topology, directly heated output triodes, zero feedback, paper-in-oil capacitors, custom-wound transformers—and the same gorgeous metalwork, which manages to appear both organic and high-tech at the same time. (Schembri's architect girlfriend, Joëlle, contributed to the design.) The Solista is a true integrated amplifier, not just a power amp with a passive front end. It has three active stages altogether: The input signal begins its journey at the potentiometer and, for voltage gain, goes on to a 6C45B triode—a tube of very low impedance. From there the music carries on to a 6H30 octal dual-triode, which Schembri describes as similar to the near-ubiquitous 6SN7, but with lower transconductance (and, he suggests, sweeter sound). The 6H30 drives the big 845 output triode, to which it is capacitor-coupled. The power supply is distinguished by another Viva hallmark: tube rectification, using for the job a dual-mono pair of directly heated triodes (211s or another pair of 845s). From there it's a straightforward pi filter, albeit one with the unusual refinement of paper-in-oil capacitors. Like all single-ended amplifiers of traditional (ie, non–parallel-feed) design, the Viva Solista requires two very large, air-gapped output transformers: In addition to passing an amplified audio signal of (hopefully) wide bandwidth, each transformer's primary must also carry the rail voltage from the power supply to the anode of its respective output tube—in the case of the 845 triode, a whopping 820V. The Solista's transformers are custom-made in Italy to Amedeo Schembri's exact specifications, said specs including the need for a single-wire primary and a single-wire secondary, with absolutely no breaks. The secondaries, in fact, are soldered directly to the loudspeaker connectors, also designed by Schembri: low-mass copper (to minimize eddy currents) plated with palladium for good conductivity and resistance to corrosion. The Solista, which measures a generous 20" from front to back and weighs more than 90 lbs, is made entirely by hand, with point-to-point wiring (using Viva's own silk-insulated, high-purity copper) and an endearing mix of old and new technologies: logic parts for the optional remote control are only inches away from a phalanx of bypass capacitors damped with what appears to be wool felt. Throughout, the watchwords are simplicity and purity: Negative feedback is banished altogether, and passive filtering is applied to all the filament voltages in place of regulation—which Schembri says makes an amp sound terrible. The specified power output is 22Wpc into 8 ohms, the only load provided for—remember, there's only one secondary winding per transformer. There are four line-level inputs, alongside an extra pair that bypasses the potentiometer and first gain stage, so the Solista can be used as a power amp only. (In power-amp-only mode, with one fewer gain stage, the Solista inverts signal polarity, making it necessary to swap hot for ground and vice versa somewhere else in the chain. And by now, Clark Johnsen's ears are ringing off their hooks.) The first time
It was cold outside the first time I heard a Solista: I was in Manhattan, visiting Ears Nova at their new Upper East Side loft, when owner Joshua Cohn—a Linn-Naim man of the first water—told me he'd finally found a tube amp he liked. No, make that loved. This I had to hear, so Joshua proceeded to play a June Tabor album through the Solista in one of the Ears Nova listening rooms, driving a big pair of Harbeth loudspeakers. It was magical. Now I've spent a number of weeks—hot, humid weeks—using the Viva Solista in different settings. I tried it as just a power amp, driven by my Fi preamp and various other review samples that came though the door, and I got some good music out of it that way. But in the end, I decided that the Solista integrated, used as an integrated, towered over the Solista as a separate power amp, used with whatever else. That may be because Amedeo Schembri took great pains to ensure that the sounds of the Solista's own preamp and amp complemented one another, or it could be a simple matter of the input and output impedances of the different sections being optimized for each other. There were certainly none of the usual integrated-amp penalties with the self-contained Solista—meaning there was none of the hum and noise associated with suboptimal parts placement. In fact, the Solista proved to be one of the quietest SETs I've ever used, ranking in that regard alongside the combination of the Lamm ML2.1 monoblock amps and Lamm LL2 preamp. The Solista, like that first SET Harvey heard, was consistently, impressively dramatic. When I listened to the version of "Ragtime Annie" from David Grier's Hootenanny (LP, Dreadnought 9801), it was easier than ever to hear when one or more of the players backed off, either to make room for someone else's solo or just as a means of dynamic shading: The effect was closer than usual to being in the room with them. At the other end of the spectrum, even driving my Quads, the Solista did a wonderful job tracing the many sharp jabs of sound—moments of violence, panic, fear, and outrage—in Hartmann's Symphony 2, as performed by Karl Anton Rickenbacher and the Bamberger Symphoniker (CD, Koch/Schwann 3-1295-2). An aside: I still like to listen with the windows wide open on summer mornings, and that's how it was today, when I went to play the Hartmann again. But as I was walking back to my chair after starting the CD, I noticed a group of wild turkeys on my property—and when the xylophone, glockenspiel, cymbals, and such made their first, loud entrance, those turkeys took off like the devil was coming after them with a can of cranberry sauce. I'm not saying that the turkeys ran faster from the sound of the Viva amp than they would have from, say, a Krell KSA-200. (I suppose I could have measured their speed and satisfied at least one portion of our readership.) I just thought it was interesting. Another fine thing about SETs is the way they can make even indifferently recorded pop music sound captivating and there—a good case in point being Martin Newell's charmingly sad "Wicked Witch," from his Radio Autumn Attic (CD, Cherry Red CDB RED 206). It sounds flat and fake through normal amps, but through the Solista it came to life: Voices and instruments became fatter, and small details, such as the squeak of fingers on wound strings, popped out the way such sounds do in real life. The Solista's stereo imaging capabilities are also worth mentioning. Volume level for volume level, the big-sounding Viva brought instruments and voices forward a bit (albeit not as much as what I tend to associate with, say, those selfsame solid-state British amps known for their good timing characteristics) and endowed them with good wholeness and solidity. The voices in Matthew Locke's "How doth the city" (CD, Nimbus NI 5454) were pleasantly chunky and distinct from one another, spread across a stage that was larger than I'm used to hearing—although they didn't have quite as much of that realistic, hear-around spatial quality as through the Lamms. Oh well, whatcha gonna do. And on recordings in which the element of motion is crucial, such as Georg Solti and John Culshaw's famous Wagner Ring cycle (LPs, London OSA 1309, et al), the Viva did a superb job of following the action. Complaints? Only the unsurprising observation that the Solista was often overfull in the bottom two octaves—too resonant, not quick enough in going from note attack to note attack. It definitely made the electric bass line in the Jayhawks' "Blue," from Tomorrow the Green Grass (LP, American 43006-1), sound sluggish. Likewise, it slowed the acoustic bass in Ricky Skaggs' brilliantly recorded version of "Walls of Time," from Ancient Tones (CD, Skaggs Family SKFR-CD 1001), which begins most measures by playing a double eighth note—something that's easier to hear through other amps. But with an amp such as this, it always comes back down to two things for me: tone and presence. Tone, for me, is a roomy term comprising a great many things, including not only timbre but also a quality I tend to think of as richness, which encompasses a component's ability to present sonic details—not musical ones, in this instance—with not only a believable amount of texture but a believable depth of texture (in the sense that some corduroys or velvets are deeper than others). I begin by wondering, Do the strings sound stringy? Do reeds sound reedy? and so forth, but it can go a great deal deeper than that. This sense of texture is both simpler and a lot more complex: Presence is presence, and I'm happy to leave it at that, in the assumption that you have both some sense of what I mean and some inclination to take my word for it when I say that something does or doesn't get it right. In any event, in both those sonic regards, the Solista satisfied me completely—as it did in the more elemental, musical sense of notes and beats, whereby the Solista made music consistently, unfailingly interesting and colorful. So here I am on a summer night, which at this time of year is only slightly cooler than a summer afternoon. I'm listening to an old standby, not just because I love the music and I crave hearing it on a night like this, but because it sounds good and meshes nicely with an amp like this: Brahms' Clarinet Quintet on a 1962 Decca LP (SXL 2297). The rest of the family is in bed, sensibly enough, and if it were colder outside I'd be enjoying a nice whisky or something, and I might even be wearing my favorite burgundy paisley shirt. And now I'm wondering: How in the world could any sane person consider it wrong to buy whatever it is they enjoy, assuming that they can afford it, and that neither their buying decision nor the product itself will bring harm to anyone? Count me among the ones who think it's almost infinitely wronger, not to mention stupider, to do otherwise.
jpg(2009/5/17 16:52:42 上传)
The Solista
Direct heated triodes
Single-ended 845 output
Zero feedback
Pure Class A
Point-to-point handwired
Remote volume control
Direct amplifier input
Buffered auxiliary pre-out
Massive custom transformers
User selectable 211 or 845 rectification
The Solista, with its same 845 output tubes and tube rectification as the Aurora, and a preamp section based on the same amazing 6c45 tube that forms the heart of the spectacular Linea 45 preamp, delivers incredible bang-for-the-buck. Try to find any high-end linestage or amplifier at this price that can deliver the performance of the Solista, let alone do both for one price. Designer Amedeo Schembri is single-handedly challenging previous beliefs that the integrated amplifier must necessarily be inferior to separates. Again, through careful implementation of power supply design, combined with brilliantly creative, yet simple circuit topologies that employ only the finest, carefully selected components, Schembri has re-written the book on what is possible from a single chassis. This amplifier, which features remote volume control, delivers the heart and soul of the music like no other integrated amplifier in the world. The familiar Viva sound, which is both liquid, yet extended in both frequency extremes, brings all the power, impact and control of the big high-end contenders. Not for a moment, though, does it sacrifice the delicacy, emotion and sheer musicality, that, otherwise, only live music is able to evoke. Viva's top-of-the-line integrated is becoming famous at audio shows for making speakers "sound better than ever..." combining power and finesse to create a musical experience that can only be surpassed by Viva's own large monoblocks via the Linea 45 linestage.
