感受专业监听的魅力-引入TANNOY ELLIPSE 8 [复制链接]
查看: 12667|回复: 28
先上图片及主要参数.........................
Tannoy Ellipse 8
System, Ellipse 8
3-Way Semi-Active Near Field Monitor
Frequency Response40Hz - 50kHz (+/- 1.5dB)
Max. SPL (@ 1m)114dB (continuous)
Max. SPL (pair @ mix position)118dB (continuous)
Dispersion (-6dB)90 degrees
Crossover Frequency     1.7kHz(DSP Generated) & 16kHz (Passive)
Drive units200mm (8") Tannoy Dual Concentric™, 25mm (1") WideBand™ SuperTweeter™
Cabinet Volume/LF Alignment18 Litres/Bass Reflex
Dimensions (H x W x D)373mm x 460mm x 361mm (145/8” x 181/8” x 141/8”)
Cabinet ConstructionLaminated birch/MDF baffle with grey suede paint finish (Black on SuperTweeter™)
Total weight14 kg (30.8lbs)
ELECTRONIC SYSTEM
Mains Voltage100 to 240Vac, 50 - 60Hz (auto - select)
Power Consumption45W @ 1/8 Full Power (IEC 6065)
AmplifierWoofer - Separate 200 PWM amp, Tweeter & SuperTweeter - 200 PWM amp
ANALOGUE SECTION
Input connectorsXLR balanced (pin 2+, pin 3-)
Selectable Full Scale Input level+9, +15, +21, +27 dBu
Multi-function LED indicator: Green for: System on, Red for: Stabilisation pior to system on. Fault (such as DC), thermal trip, clipping of LF amplifier, Yellow for: VLF warning (presence of subsonic signals below 20Hz, increasing in sensitivity down to 1Hz) Trim Controls: Hi: Shelving filter +/-3dB @ 25kHz (+/-1dB @ 4.5kHz), Mid: Bell filter +/-2dB @ 1.4kHz - 0.45Q, Low: Variable alignment LF hi-pass filter +/-3dB @ 45 Hz (+/-1dB @ 90Hz)
照片tannoy 002 (Medium).jpg (, 下载次数:994)
jpg(2009/2/16 9:17:27 上传)
照片tannoy 003 (Medium).jpg (, 下载次数:973)
照片tannoy 007 (Medium).jpg (, 下载次数:951)
最后编辑mackiel 最后编辑于 2009-02-16 12:33:39
图呢?
诚求叶立老师的前级,有源、无源的都要!
回复 1# mackiel 的帖子
想请教一下,如何领悟到"专业监听的魅力"
这应该是很好的东西啊,先顶一下!
音箱:卓丽 比家
功放:hegel h200
CD机:君子 apollo
请上听音报告,愿闻其详!
真tnd怀念我的老战友啊~~~
最后编辑millsoft 最后编辑于 2009-02-16 23:42:45
继续,先转贴一篇枪文
器材評論/陸怡昶
把錄音師的工作伙伴搶來用!
Tannoy Ellipse 8主動式鑑聽喇叭(最佳推薦)
在錄音製作的過程中,準確地反應聲音的成分與變化,這是鑑聽喇叭的天職。如果錄音師聽到的、就是您想聽到的,這對Ellipse 8可以實現您的願望。它擁有高解析度與控制力,整體卻呈現出圓滑與溫暖的音質,播放各種型態的音樂都很適合。
三音路主動式鑑聽喇叭,低音反射式箱體結構,200mm雙同軸單體×1、25mm超高音單體×1,箱內容積19.5公升,分頻點1.7kHz/14kHz,內建擴大機功率LF:150W/HF:150W/ST:30W,頻率響應40Hz—50kHz(±3dB),最大輸出音壓(peak @ 1m,失真0.8%以下)112dB,XLR輸入端子,輸入阻抗22k歐姆,輸入靈敏度+4dBu—-10dBu,訊噪比高於100dB,失真率低於0.5%,水平擴散角(@6dB)90度,尺寸373×460×350mm(HWD),重量15公斤。參考售價:180,000元(一對)。進口總代理:功學社(02-23254321)。
外觀:「Dual Concentric」是一個同軸二音路單體,它相當與一個高音單體加上一個中低音單體:8吋PP(聚丙烯)音盆負責1.7kHz以下的中頻與低頻段,「Dual Concentric」單體的中央深處則是一個鋁合金凸盆半球高音,負責1.7kHz-14kHz頻段。
背板:Ellipse 8採取三音路電子分音,每一支喇叭內部一共有三組功率放大電路:同軸單體的高音與中低音各用一組150瓦的MOSFET放大器驅動、超高音單體則是用30瓦的功率模組(IC)來推,總計每聲道內建的放大電路功率高達330瓦。
3:在輸入級之後,聲音信號送進具有三段等化功能的「Trim Control」電路,以「Hi Trim」、「Mid Trim」和「Lo Trim」三個旋鈕作調整:「Mid Trim」是一個Q值0.45的濾波電路,中心頻率在1.4kHz,增減範圍±2dB;「Hi Trim」與「Lo Trim」則可在20kHz與40Hz作±3dB的調整。
個性焦點:Ellipse 8的速度雖快,但因中頻、低頻的量感充足,使它即使在大音量放音時,全頻段仍有良好的均衡性,沒有一般Monitor「前衝」的通病,聽感十分舒適,整體的聲音有著豐富的層次感與細節,超高音頻段的延伸極佳。
搭配建議:基本上訊源與前級的選擇以平衡式機種為主,以我個人的偏好,我建議使用音質中性、解析度高的器材作搭配。由於Ellipse 8的箱體是「橫式」的,因此選用的喇叭腳架要比一般製品稍高一些(大約75公分)。
參考軟體:「Face Value」的錄音製作很考驗音響系統的能力。Ellipse 8極佳的暫態反應、控制力與瞬發的充沛能量,在第一曲In The Air Tonight後段,相當真實地表現出猛力敲擊爵士鼓的勁道。當第8曲You Know What I Mean播放時,鋼琴的泛音豐富,細膩完整地描繪出鋼琴複雜而優美的音色。(Atlantic 16029-2)
大部分新一代音響玩家們只知道Tannoy的家用喇叭,事實上Tannoy從創立之初就已經在製作專業製品,也許有些老玩家還記得在十多年前Tannoy鑑聽喇叭的旗艦—215 DMT曾經作為錄音室的標準鑑聽器與不少專業音響雜誌的參考喇叭。在DMT系列之後,Tannoy製作鑑聽喇叭從未間斷,而隨著SACD與DVD-Audio訊源的出現,舊有的許多鑑聽喇叭(不分品牌)已經漸漸不能滿足超高音頻段再生的需求,Tannoy於是在2002年推出應用該廠「Wideband」技術的Ellipse系列。
以同軸單體為主,加入超高音單體擴展超高音頻段的延伸
Ellipse系列包括Ellipse 8與Ellipse 10兩種款式,編號中的數字代表著同軸單體口徑,因此本篇的主角Ellipse 8採用的是8吋「Dual Concentric」單體,這是Tannoy固有的特殊設計。此「Dual Concentric」是一個同軸二音路單體,它相當於一個高音單體加上一個中低音單體:8吋PP(聚丙烯)音盆負責1.7kHz以下的中頻與低頻段,「Dual Concentric」單體的中央深處則是一個鋁合金凸盆半球高音,負責1.7kHz-14kHz頻段,在振膜前方以鬱金香導波器(導波器的橫切面像是鬱金香的形狀)將高頻聲波導出,並且利用高音周緣的金屬部分與PP音盆當作高音的號角,達到控制擴散角的目的,因此裝有「Dual Concentric」單體的Tannoy製品就結構上而言,可視為同軸號角喇叭。
Tannoy之所以要做成同軸結構的目的,就是希望喇叭能採取與自然界相同的「點音源」發聲方式,無論在時間、相位與發聲位置,「Dual Concentric」都能讓兩音路的聲音能接近完美地結合為一體,然而號角結構的高音受限於先天的物理條件,傳統的高音號角大約在15kHz以上就會快速衰減,Tannoy當然很明白這一點,於是為Ellipse 8加裝了超高音單體,鎖在獨立的橢圓形小箱體,盡可能與同軸單體靠近,使超高音與同軸單體間也形成類似點音源的發聲型態。這個1吋超高音單體擔任14kHz以上以上的頻段,頻率響應的上限在50kHz以上,超高音振膜所在的前後位置與同軸單體高音振膜相當,此手法是為了使超高音與同軸單體發聲能同時抵達聆聽者的所在位置,得到時間的一致性。從以上的敘述中,您就能夠理解Ellipse 8是一款三音路喇叭,這三個音路分別為中低音、高音與超高音,而不是一般傳統三音路的低音、中音與高音。
橢圓形可降低繞射波的反射
Ellipse 8採用多層樺木板製作箱體的橢圓型部分,面板與背板則是採用MDF板製作,相當堅固紮實。之所以要把箱體做成橢圓形,與造型設計毫無關係,它是為了降低繞射波在面板上的反射,這樣的製作手法與「窄面板」喇叭箱體設計意義是相同的,在實際聆聽時用家可以感受到音像的清晰度較傳統設計高出不少。以箱體結構來看,Ellipse 8歸類為低音反射式,兩支低音反射管的出口都在正面,原廠為每支喇叭附上了兩個泡棉塞,在一般使用狀態下不需要使用,喇叭背板與牆面距離不到1.5米,低頻會因牆面反射的作用而增加時,用家可將泡棉塞插入反射孔,對牆面反射而增加的低頻作修正;另一種需要使用泡棉塞的狀況則是在Ellipse 8搭配主動式超低音喇叭使用時。泡棉塞子用與不用,在頻率響應方面的差別主要是在150Hz以下低頻段的量感,當泡棉塞入後,Ellipse 8則從低音反射式變為近似密閉式箱體的狀態。在喇叭箱體底部中央,裝著一個圓形的氯丁橡膠(neoprene)底座,使Ellipse 8可以穩定地座放在喇叭腳架或平台上、不易滑動,並且橡膠材料有抑制振動的作用,用家不需要額外使用墊材。
Trim Control有效改善響應
在電子電路方面,信號從背板的XLR端子輸入後,輸入級採用一個高CMRR的電路將信號線感染的共模雜訊消除,以背板上的「Sensitivity」旋鈕控制此放大電路的增益,作靈敏度調整(範圍為+4dBu—-10 dBu)。在輸入級之後,聲音信號送進具有三段等化功能的「Trim Control」電路,以「Hi Trim」、「Mid Trim」和「Lo Trim」三個旋鈕作調整:「Mid Trim」是一個Q值0.45的濾波電路,中心頻率在1.4kHz,增減範圍±2dB;「Hi Trim」與「Lo Trim」則可在20kHz與40Hz作±3dB的調整。由於採用低Q值濾波器的緣故,因此以上所說的1.4kHz、20kHz與40Hz只是該段調整「變動幅度最大的部分」,事實上「Lo Trim」調整的頻段涵蓋200Hz以下、「Mid Trim」涵蓋100Hz-20kHz,「Hi Trim」涵蓋2kHz以上的頻段,以「Mid Trim」為例,距離1.4kHz愈遠的頻段在進行調整時變動的幅度愈小。這樣的設計來看,基本上是針對聆聽空間的響應作補償,一般只要調整好「Lo Trim」就夠了,如果玩家想要加強泛音的部分,讓所謂的「空氣感」更強烈一點,也只需將「Hi Trim」稍微調高一些。
喇叭失真率低於0.8%!
Ellipse 8採取三音路電子分音,每一支喇叭內部一共有三組功率放大電路:同軸單體的高音與中低音各用一組150瓦的MOSFET放大器驅動、超高音單體則是用30瓦的功率模組(IC)來推,總計每聲道內建的放大電路功率高達330瓦。由於採用主動式分音的緣故,功率放大電路的輸出是「直接驅動」喇叭單體,其間完全沒有被動元件的損耗,並且Tannoy製作的喇叭單體效率向來較高,這些因素加總起來,使Ellipse 8的最大輸出音壓(每一支)達到112分貝,一對的最大輸出音壓則是118分貝,這樣的條件除了在專業用途作為近場鑑聽之外,使用在一般居家空間的客廳以較長的距離聆聽也能得到充足的音量,還能為用家省去購買大功率後級的費用。更值得留意的是Ellipse 8在「最高輸出音壓」的狀態下,失真率低於0.8%,一般音量聆聽時失真率則為0.5%以下。這有什麼了不起?您別忘了這是一對「喇叭」、不是擴大機喔!絕大部分(保守估計九成五以上)喇叭規格均未標示失真率,失真率難道不重要嗎?為何大家都很有默契地忘記標示呢?
LED燈號與防護措施
由於Ellipse 8是以專業用途為主,在錄音室中整天連續工作是常有的事,因此安全性與保護措施相當重要。裝在背板上的散熱片長得跟別人不一樣,沒有「片狀」的散熱翼,而是多個棒狀的突起,與同體積的一般散熱片相較,散熱效率高出60%,若功率放大電路持續地高輸出一段長時間,散熱片溫度超過攝氏70度,它會自動切斷電源。在面板中央下方裝有一個LED,電源開啟後,LED燈號為綠色,當輸入信號中帶有人耳聽覺範圍之外的極低頻(VLF),LED燈號就會轉為黃色,並以內建的濾波器把信號中15Hz以下的成分砍掉。倘若在聆聽過程中,LED出現紅色燈號時,多半是因為負責驅動低頻的功率放大電路已經切割失真了。功放電路過熱時,LED也會轉為紅燈,用家僅需關掉電源十多分鐘充分散熱後,重開電源即可恢復正常工作。
器材搭配與近場鑑聽
實際搭配試聽時,為了更真切地掌握Ellipse 8的聲音特性,因此我連前級都沒有使用,只取Cary CD 303/300(CD唱盤)的平衡輸出(選用固態輸出),這部CD唱盤有音量控制,且平衡輸出信號大小有6V,即使不用前級,也能輕易地讓輸入靈敏度高的Ellipse 8全功率輸出。隨即比較泡棉塞用與不用的差別,不使用海綿塞的時候低頻較為寬鬆,中頻下段也比較生動,所以接下來的聆聽過程,我都是以不使用泡棉塞的狀態下進行試聽。
一開始我先採用原廠建議的擺位法作近場鑑聽,這樣的聽法可讓空間響應的影響降到最低,此時Ellipse 8就如同「大耳機」一般,直接地把聲音灌入耳中,但相當難得的是這對鑑聽喇叭的聲音並沒有咄咄逼人的強迫性,它的速度感是「快」而不是某些高價位Monitor的「極快」,相對顯得較為和緩,因此在音樂的表現上並不會顯得急促而緊張,音樂中應有的韻味仍能充分地表現出來。Ellipse 8雖原為專業市場開發的製品,但它擁有舒適的聽感,亦使其具備「跨界」作為家用音響器材的條件。既然要把它當作家用器材聆聽,我把喇叭間距以及座位距離都加大到2.4米,仍採取正三角擺位法,因為音壓與聆聽距離的平方成反比,所以在加大距離後,Ellipse 8內部的放大電路必須付出更大的功率。
各頻段聲音完美地結合,敏感地反映軟體與訊源的特性
在聲音個性方面,Ellipse 8是以濃郁的中頻為基礎,這是正統英國系喇叭一貫的特徵,低頻也頗有份量,在相近尺寸的喇叭當中,這款製品的聲底是相對厚重的,低頻punch的力道強勁,猝發與停止相當明確,使它展現出清晰的低頻輪廓,在刻意加大音量之後,中、低頻與高頻仍維持與一般音量聆聽時相同的比例,絲毫沒有高頻突出、聲音變得白熱化的傾向。從低頻到超高音頻段,三音路的速度、音色與能量銜接非常理想,聽起來就像是一對擴展超高音與低頻段的全音域喇叭。在試聽過程中,我切換Cary CD 303/300「Sampling-Rate Converter」的檔位,從96kHz、192 kHz…逐檔向上切換,當我在其他系統上試聽時,每提高一檔的音質變化並不太明顯,只能大概「感覺」提高一檔「好像」比較好聽,然而用Ellipse 8聆聽時,取樣率每提高一檔,就能明確地聽出情報量有顯著的增加。這對喇叭並不是模糊地讓我覺得「好像比較好」,而是很確實地分辨出訊源的品質,將提昇取樣率後線性更佳的特質完整地呈現出來。Ellipse 8是需要暖機的,如果您親自去試聽,電源剛開就已經覺得聲音真是不錯,我能肯定地告訴您:在暖機之後音質的純度還會更高,如果用家不在意多花一點電費,可以不必關機。
最佳推薦
在眾多的鑑聽喇叭當中,Ellipse 8的聲音是很特殊的。一般被認為較為中性的器材,通常傾向於冷調性,中低頻緊實而非寬鬆,而Ellipse 8同樣擁有高解析度與控制力,整體卻呈現出圓滑與溫暖的音質,讓用家能輕鬆地聆聽。在即將寫完本文之前,我才得知它的售價,與聽過這對喇叭的同事們交換過意見之後,我們決定給予Ellipse 8最佳推薦,畢竟要以相同代價(18萬台幣)找一對喇叭和後級的組合,整體表現要達到與Ellipse 8相近的水準並不容易,並且透過「Trim Control」調整能適應空間響應與用家的喜好,為了得到好聲音,把錄音師的工作伙伴搶來用,不算過份吧!■
音響知識 Tannoy建議的近場鑑聽擺位方式
鑑聽喇叭的設計,絕大多數都是希望降低空間反射音的成分,讓使用者以聆聽直接音為主,盡可能排除不同空間造成的變數,如此才能夠確保聲音重播的準確性,因此Ellipse 8的水平擴散角僅有90度,並建議專業用家採取正三角擺位法作近場鑑聽,喇叭間隔與喇叭至聆聽者的距離皆為1.3公尺,喇叭需要作精準的toe-in,讓同軸單體的高音部分直指聆聽者,原廠在使用說明書中提供了一個簡單的檢視方法:如果您在聆聽座位上可以看到兩支喇叭同軸單體正中央鬱金香導波器之內金色的高音振膜,這就表示toe-in角度已經調整得相當準確了。
最后编辑mackiel 最后编辑于 2009-02-16 14:31:31
喜欢有源,就是外形有点接受不了
男人要多听音乐,才不会胡思乱想。
这一款音箱像火星来的另类,很怪。难以相像传统的英国佬也能搞出这种怪胎
我觉得好Q。
