关于线材配搭想请教一下。 [复制链接]
查看: 3412|回复: 4
前段时间受了两条喇叭线,想请教一下。
上面那条是铁三角 AT6S30 单晶铜
下面那条是线圣   SR-15/4 单晶铜
AT6S30在二手市场买二手的线,40块一米,SR-15/4在淘宝买的,85块一米。
两条线先后用在我的TEAC 225 台式组合里面发觉 线圣的声音高音发干,低频量少,声场很压抑。
反而铁三角便宜一半的线,高音甜些,低频量适中,声场靠后,听下去舒服多了。
想问在淘宝买的是不是假的线?就算线圣的速度快,没有低频,那么声场都不应该是压抑的啊。
ps:单晶铜都是有方向接的,铁三角的线没有箭头指示,那么如何分辨方向啊?
双线分音的单晶铜,如果只开一组,那么用里面那组和用外面那组声音上会不会有分别?(如图)
aq的 sr15/4   不太合适发烧,我早期看到过很多,一米几元,但是试听过后,就放弃了,反而 14/2  会润泽一些。 价格也好。楼主试试比较就知道。
38“毒物”
原帖由 38度5 于 2009-4-22 11:26:00 发表
谢谢!几元一米?是上图那款吗?
38“毒物”
因为买的时候没有去细心了解AQ线各系列的功能。今天刻意去了http://www.audioquest.com/   看过。
先谢谢楼上的价格参考。我的SR15/4确实买贵了,但是现在也不确定是否真品。
但是以官方的设计,SR系列是比FLX系列高一点点的。在官方下载的pdf看到这段话。
The SR cable series is most unusual because each cable has a 100% coverage shield. Each conductor is
tightly held in high temperature PVC and the overall cable is jacketed in a slippery high temperature PVC
jacket. This outer jacket is abrasion and heat resistant, and can be used in a variety of harsh environments.
The SR-16/2 and SR-16/4 cables sound better than the FLX 16/2 and FLX 16/4, have lower resistance,
and are shielded. A tape under the jacket of SR cables is printed with sequential feet numbers.
大意是,SR是SHIELDED ROUND的缩写,意思是屏蔽的圆柱。
所以SR系列比起FLX系列有屏蔽性,耐热,耐磨的特性,所以是比flx系列贵的。
也去过国外的电子商务网站,FLX都买¥44-50美元的。这个很不解。国外卖这么贵。
AudioQuest FLX 16/4 uses 4 of the same conductors found in FLX 16/2. The 4 conductors
are separately color coded so that they may be used with two conductors tied
together (13 awg, 2.27sq. mm) to carry a single channel signal, or separately so one
cable can carry two signals.
一位国外的网友这样对比这两款线:
Just upgraded to the SR (Shielded Round) 15/4 series. Very nice and a better more silky treble compared to the FLX16/2 I was using earlier. Needs a wee bit more bass though but since these cables are sponsored I'm not complaining  The SR15-4 consists of 4 X 15 LGC (long Grain Copper) awg wires and can be used for bi-wiring. When used for std setup 2 wire are combined into a 12 awg wire. Only downside I can think of is price and the size (diameter) of the cable. The large diameter makes it more difficult to route through tight areas.
http://www.audioquest.com/pdfs/custom_install/sr_series.pdf
  Logged
看来SR 5/14这款线不会至于我这个情况,要查查线的真伪。
