最疯狂的发烧友,最疯狂的器材…… [复制链接]
查看: 6111|回复: 7
超过两米的号角巨人+低音炮超过4吨重,教堂般宏伟的听音室,用高科技产品TACT自动根据空间校声,动用了6台贵丰、十多对cary胆机驱动,电源从独立的配电箱中引出……
不说了,自己看看吧
http://dan.bellity.online.fr/jyk/
Behind horn colomn, Woofer colomn.
Each of the 4 colomn is about 1000 Kg ! (total 4000Kg)
Speakers are desiged and built by Klinger Favre
left side with the table where sources are .
CD drive is Teac P0, Upsampling and clock master done by DCS, Room correction done by TACT RCS2.0, Dogital Pream is Accuphase.
Command Post.
For Tact Room correctors
This is a view of the amplifiers room. (behind the front wall of the room)
all electronics and crossover for each side
Sub bass: amplified by a Gryphon Solo mono bloc - 0 => 71Hz slope —\ 48
4 woofer using JBL 2227H (push pul with 3m Horn)
Mid bass: amplified by a Gryphon Solo mono bloc - 71=> 180Hz slope 48 /—\ 48
2 woofer using JBL 2227H (with 1,80m Horn)
High bass: amplified by a Gryphon Solo mono bloc - 180=> 400Hz slope 48 /—\ 24
2 mid-bass 10 " Horn using TAD 1201H
Low midrange: amplified by a Cary CAD 1610 SE mono bloc - 400=> 2000Hz slope 24 /—\ 24
1 drivers 3" JBL 2490H
Midrange: amplified by a Cary CAD 1610 SE mono bloc- 2000 => 5000Hz slope 24 /—\ 24
1 driver JBL 2" JBL 2450 H
High Midrange one : amplified by a Cary CAD 1610 SE mono bloc- 5000=> 10000Hz slope 24 /—\ 24
1 driver JBL 1.5" JBL 2451H
High Midrange one : amplified by a Cary CAD 1610 SE mono bloc- 10000=> 14000Hz slope 24 /—\ 24
1 driver JBL 1" JBL 2426H
Tweeter: amplified by a Cary CAD 1610 SE mono bloc - 14000 Hz => top slope 24 /—
2 driver JBL 2404 JBL + 1 super tweeter Klinger Favre
Crossover are, Accuphase digital Crossover and some time BSS 366 (3 pieces)
Power conditionner separated for each kind of unit (depending need)
Power Câble from SHUNYATA (USA)
(selected for them nutral sound).
listening room details.
previous pictures for you to know to what the room look like.
Room informations
-Lenght: 15,34m
-width : 6,375 wall to wall and 6,665 wall to window glass thickness 15 mm
-height maxi: 4,095
-beamheight : 15 cm
-Wood coffered ceiling acousticaly modified.
-Parquet floor steady on a cement slab
-large carpet 8m x 4m
-Window dimension : height 3.60 m , width 1.10 m
-wood blind
Rock wool behind curtains in the back of the room. Each Rock wool layer is 20 cm thick
Wall are juste in plaster painting finished
Some Painting on wall and a large mirror on the front wall.
贴上来,这样会有更多发烧友观看。
我记以前看过一外国文章,那鬼佬用的超低音是用地下室做的,,,就像是一个超大的箱体,,,这更疯狂。。那文章现在找不到。。。
等我买了别墅再买它,哈。。。。。。
平衡调得好么?胆机+石机一起推
效果真的好麽?
我唯一能比得就是使用RCS2.0。
那些是我想都不感想的器材!
