哪位DX用过这台唱放?声音如何? [复制链接]
查看: 4019|回复: 7
价格才2k多,有意。
Pro-Ject Tube Box II
Pro-Ject Tube Box II Features:
# Phono MM/MC selection switch located at the rear of the unit
# Selectable Subsonic filter
# Metal case shields the electronics from vibrational and
electromagnetic interference
# Optimal channel separation through dual-mono circuitry
# Gold plated RCA connection sockets
# Outboard power supply included
Pro-Ject Tube Box II Specifications:
# Tubes 2 x ECC83 (12AX 7A)
# Input impedance, MM 47kohms/120pF
# Input impedances, MC 100ohms/120pF
# Gain, MM 40dB
# Output voltage typically 300mV/1kHz 3mV/1kHz (MM input)
# Gain, MC 60dB
# Output voltage typically 300mV/1kHz 0,3mV/1kHz (MC input)
# Noise floor, MM 84dB (94dB -A weighted)
# Noise floor, MC 67dB (75dB - A weighted)
# THD, MM 0,05%
# THD, MC 0,08%
# RIAA-equalisation curve accuracy 20Hz - 20kHz / max. 0,5dB
# Subsonic filter at 18Hz with 18dB/octave
# Power supply type Mains-fed outboard power supply
# Output voltage 16V/1.000mA AC
# Power consumption 16V/410mA AC
# Dimension W x H x D 103 x 76 x 141mm
# Weight 810g without power supply
[em5][em5][em5][em5]
哈哈,是“唱针医生NEEDLEDOCTOR”网站的资料吧,没用过,样子不错。
能达到麦景图C200前级自带的唱放一半功力我就满足了,听过朋友的C200前级唱放,声音丰满圆润,空气感强,层次清晰开阔。
音乐迷 在 2007-1-6 22:34:42 发表的内容
据说麦景图C200的唱放部分是麦厂向高度风厂订做的,应该不差了吧。
难怪
jacky70 在 2007-1-6 22:39:07 发表的内容
不是太好,加入你的唱盘是3-5K级别,还可以用。反正听个声音,味道是没有的。
呵呵,看来要放弃了。
jacky70兄有推荐的吗?
宝碟唱放胜在够便宜,这个价钱就不要对声音有太高期望了。
另外,C200的内置唱放质素一般,和大约同档次的BOULDER差距相当明显。
