有了解加拿大Totem音箱的吗? [复制链接]
查看: 4424|回复: 10
很喜欢这对
原厂比较用心哦
1. Break in time
Wind 200-250 hours
2. Amplification
100 watt + Wind
5. Toe-in or not
Due to the fact that all Totem speakers have great off-axis dispersion, toe-in is generally not needed.
Imaging will therefore be more stable from any point in the room. If the speakers are placed very far apart (over 7 feet) then a slight toe-in may be experimented with. However if room geometry does not permit a straight-ahead aspect they will also perform very well with a slight toe-in.
7. Placement: from rear wall
Model Minimum Maximum
Wind 3 feet  7 feet
8. Placement: distance apart
Wind 6 feet  14 feet
摸样好怪!
名级潜水艇 在 2005-9-21 15:28:55 发表的内容
摸样好怪!
怪!?我觉得潮爆啊!
WIND
A totally unique (4x) driver 3-way speaker system.
Like a true Totem pole, showing many faces and
telling a story. The Wind stands for flexibility and truly full range expressiveness.
The multiple midranges allow for an incredible amount of musically informative material to transpire in space with ease. The sound level possibilities of this large dynamic system also facilitate large and complex musical demonstrations.
Design and performance are brought forth in a flexible and manageable equilibrium.
Let its many faces unfurl the musical message behind its story.
Truly full range expressiveness
?Its revolutionary cabinet design allows for true
?on and off axis point source imaging
?The upper cabinet geometry allows for an
?uncluttered visual field blending exemplary
?imaging characteristics with unobtrusive
?placement possibilities
?It extends beyond the confines of room and space
Specifications
Frequency Response 24 Hz to 21 kHz ?3 dB (in room)
Impedance 4 ohms
Sensitivity 87 dB
Power 250 W max. program
Crossover Woofer to mids 2nd order / 2nd order
Mids to tweeter 2nd order / 2nd order
Woofer 8.1/2?cast frame, specially damped.
High power handling. Long throw characteristics.
Mid-Woofers (2) 3?voice coil. Cast frame. High power handling.
Wrap-around neodymium magnet structure.
Accurate linear throw.
Tweeter 1?alloy dome flexible linear suspension.
Special low resonance chambered unit
Max SPL's In average room (4 m x 6 m) (12 ft x 20 ft)
114 dB peak from pair at 2 m
Dimensions Irregular
Widest w 10.5 x d 14.5 x h 44.5?
w 267 x d 368 x h 1130 mm
HONG KONG / CHINA
Clarity Development Ltd.
618 Hollywood Plaza,
610 Nathan Road,
Mongkok, Kowloon
Hong Kong
Tel: (852) 2165 - 4712
最后编辑leslie
没人听过???
天神 在 2005-9-21 14:37:08 发表的内容
好像没见到代理.......
官方网站DISTRIBUTOR 上有家HK的http://www.totemacoustic.com/english/distributors/distributors.htm
HONG KONG / CHINA
610 Nathan Road,
Mongkok, Kowloon
Hong Kong
在ABSound里面看到过,当时觉得样子有点怪.
英国的图腾卖得好贵,不是很出名,但也是HI-END的器材
好像没见到代理.......
