Benchmark DAC1 抗Jitter 的根本原因---- AD1896 [复制链接]
查看: 4525|回复: 6
Benchmark DAC1 采用了Analog Device 公司的新产品AD1896 数字接收芯片,而之前多数DAC都是采用Crystal 的CS8420.
AD1896 的重要作用,就是可以减弱jitter , 其基本原理在于AD1896不根据输入的数字信号来决定时间长短,而是根据DAC自带的主时钟和输入的数据平均码率来决定输出码率, 所以才能做到" 对转盘不敏感" , " 你可以用CD-ROM加Benchmark DAC1 超过一万美元的CD系统"
这里是一段英文,来自论坛的讨论:
Will AD1896 improve jitter rejection?  Post #1
how to connect AD1896 to improve jitter rejection?
Is input 44.1khz and output 192khz a good idea? or the ratio should be integer?
如果连接AD1896才能改善jitter消除?   输入44.1khz输出192Khz可以吗?
IP: Logged
06-10-2003 03:46 AM
jwb []
diyAudio Member
Offline
  Post #2
AD1896 will attenuate jitter. Big time. Hook it up like it says in the datasheet. Ratio makes no difference, and no matter how hard you try you won't get an integer anyway. The AD1896 (and other ASRCs) use a rate estimator to determine the average incoming data rate, and use the master clock to determine the desired output rate. Then they apply digital filters to complete the conversion. The output should have the same jitter as your master clock.
AD1896可以衰减itter. AD1896通过对输入速率的估计来决定平均输入数据流.用主时钟来决定输出速率,然后通过数字滤波器去完成转换. 输出的信号的jitter 和DAC上的主时钟一样.
I don't see any reason to not go 44.1 to 192. Your DAC is probably going to oversample this to an ever higher rate anyway.
IP: Logged
06-10-2003 04:34 AM
yejun []
diyAudio Member
Offline
  Post #3
Is it possible AD1896 has a better oversampler than normal DAC?
AD1896超采样比普通的DAC 更好吗?
IP: Logged
06-10-2003 05:01 AM
machinow []
diyAudio Member
Offline
   Post #4
quote:
yejun,
the oversampling is necessary for the digital filter, not anyway.
I suggest you if you use a sigma-delta DAC and no more than 44.1-48kHz source, to resample it to ONLY 48 kHz with the 1896 chip. This will leave more headroom for the digital filter, integrated in the sigma-delta, and it will use 8xoversampling /for example, see AD1853, AD1955 datasheet!/ If u resample to 192kHz, the DAC will be left with only 2xOversampling and the frequency and phase responce becomes uglier
超采样对于数字滤波器总是必要的.我建议如果你使用44.1-48Khz的数字源的话, 使用1896 把它重新采样成48Khz,  这样, 你的Delta-Sigma 方式的DAC就有更大空间,对于比如AD1853这块DAC就可以有8倍超采样.
So you can see it is significant what kind of source and DAC you will use. Many people here hate Sigma-deltas, but they are a lot Cheaper and good ones have very good Digital filters inside and characteristics also.
Regards
Kaloyan
IP: Logged
06-10-2003 10:11 AM
锗?怡桕 []
diyAudio Member
Offline
  Post #5
Hi All!
By the way, ad1896 wonderfully works in a synchronous mode, when it is equivalent to the ordinary digital filter with integer factor of oversampling.
From it is possible to receive 4Xoversampling for 44.1 or 48kHz.
In this mode it is comparable with digital filters SM5842/5847 and subjectively sounds better than SM.
顺便说, AD1896 在同步模式下工作的非常好. 这时候他等价于一个整数倍升频的普通数字滤波器, 他可以把44.1或48Khz进行4倍升频. 这时候,他差不多和SM5842/5847数字滤波器相当, 而且声音比后者更好.
Probably it explains in short length of the digital filter AD1896 (only 64 taps).
In an asynchronous mode, it certainly suppresses a jitter, but sounds considerably worse than SM from NPC.
这可能解释了AD1896数字滤波器的短长度(64taps ) ? (没明白)
在非同步模式下,他可以抑制jitter, 但是声音比使用SM 从NPC 中要差很多.  (难道抑制jitter并不能改善声音? )
But to apply a synchronous mode it is possible only in case of presence of separate clockline for synchronization DAC with transport.
但是应用同步模式的时候, 只有在DAC和转盘使用各自的时钟的时候才可以.
This mode can be used as with R-2R DAC, and as with the delta sigma DAC as AD1955 and PCM1738 (i.e. there, where is possible to disconnect the built-in digital filter, in the other case, with ordinary D/S DAC here is no sense in it, good anything is not present in a double digital filtration, where one of them also with fractional factor).
这种模式(同步) 可以和R-2R DAC一起使用, 加上Delta-Sigma 方式的 DAC,比如AD1955或PCM1738 ( 太难,自己看吧    )
For what to use it in a synchronous mode with R-2R multibit DACs (or inputs 1955/1738 in external digital filter mode), it is necessary to AD1896 on an output to put the shift register. It is possible to carry out synchronous reclocking at desire.
The main generator and divider is necessary for establishing in the DAC module, ad1896 to establish in slave mode (in/out) completely, and requires submission of a grid of frequencies from a divider.
From the same generator the transport / decoder should be synchronized.
Regards
Halyavshick
__________________
sorry my wrong English
综上,看来有几个观点:
1.  AD1896工作在非同步模式可以显著降低jitter
2. 据说非同步模式下AD1896声音没有"SM from NPC" 好 ?
3.  AD1896工作在同步模式下,可以做4倍升频,并且效果非常好
看来还是有几个问题不明?
1. Benchmark DAC1 是使用AD1896的非同步模式还是同步模式?
   如果是非同步,看起来比较合乎逻辑, 但jitter降下来了,声音一定好吗?  如果好,那么天价转盘就没必要了
2. 如果是同步模式AD1896,那么4倍升频会不会带来惊喜? 那么天价转盘还是必要的了.
东西是很好的,不过能跟多少万元级别的打擂台,这个可就说不好了...
但benchmark dac1对转盘的要求不是很苛刻,声音也很不错,应该算是广大贫民烧有的上佳选择之一了吧?
日本精密電路公司的SM5844AF和SM5849AF的性能與CS8420相仿, 信噪比和動態範圍均在120dB左右。其中SM5849的最高輸出採樣率可以達到192K,美中不足的是它的變換比不能突破3,不能將44.1K的CD信號直接地變換成192K的DVD AUDIO信號。看來只有指望AD公司了。實際上AD公司是生產採樣率變換電路的鼻祖,當年的AD1890、AD1891就被大量地應用在各種專業及半專業設備上。那時,此類專用積體電路清一色地由AD公司供應。在今天,AD公司挾其雄厚的技術實力不負眾望地推出了新一代的超高性能的採樣率變換電路-AD1896。AD1896的信噪比高達135dB,動態範圍更逼近理論極限的139dB,它的上下變換比更高達7.75 ~ 8。從而制定了新的採樣率變換電路的性能標準,將竟爭對手遠遠地拋在了後面。AD1896之所以有超乎想象的性能,這主要得益於以下兩個方面:1 憑藉AD公司在音頻領域和DSP領域多年的經驗和雄厚的技術實力。2 採用了AD公司創新的專利—極大化內插、超高性能數位濾波、數位伺服環技術。
AD1896的主要特性如下:
◎自動感知採樣頻率。
◎簡單易用、無需編程設計。
◎內置採樣時脈抖動衰減功能。
◎3-5V的輸入介面電平,內核採用3.3V電壓供電。
◎支援16/18/20/24比特的輸入資料。
◎可工作在1K-192K的採樣率範圍。
◎輸入/輸出的採樣率變換比從7.75:1到1。
◎具有直通工作模式。
◎多片AD1896可工作在相位匹配工作模式。
◎多片AD1896可工作在菊花鏈工作模式。
◎高達139dB的信噪比和動態範圍(A計權,帶寬20-20K,FS=48 K)。
◎對於全部的工作採樣率和輸入採樣頻率來說THD+N不劣於120dB。
◎內置高質量線性相位回應的有限脈衝回應數位濾波器(FIR)。
◎支援256FS 、512FS 或者768FS 的主時脈工作模式。
◎具有靈活的三線串列資料介面模式,包括左對齊、IIS、右對齊(包括16、 18、20、24比特資料字長度)和DSP串列介面模式。
◎採用28腳雙列SSOP塑膠封裝。
大家有空看看这篇文章:
http://xoops.govern.com.tw/modules/news/print.php?storyid=5
enrique兄又有新资料
懒虫 在 2005-7-1 16:00:26 发表的内容
8千胜8万了?前几天不还胜十几万呢?估计纯属吹牛。
补充一下, 上面说的可能不太准确. 准确的说法是, Benchmark DAC1搭配普通转盘的jitter 值非常小, 比一万美金的其他高档CD或转盘+DAC系统还小. 这可不是我说的, 而是Stereophile 主编测的.
但说不定还有另外的比较少见的数码系统比Benchmark DAC1 的jitter 更低,那就不知道了, 山外有山,人外有人嘛.
jitter 低是否听感就一定好呢? 也未必. 模拟系统也要非常好才行,或者说非常适合耳朵的听感. 某些专业监听器材指标非常高,可是听感也一般的.
我有它,觉得很不错,配胆机不愁音乐味
