求原创A8S电路图! [复制链接]
查看: 2974|回复: 5
坏了,不加电,拆开一看,机内保险丝烧了
买保险丝换上,一开机,还是烧保险,而且换两个烧两个,紧急求助!
我自己可以焊机,但不知坏了哪个零件,没万用表。
借万用表测试:
上保险丝,不插电源开机,欧姆挡测机器电源线正负级,开路
把变压器后级输出到电路版的排线拔除,再欧姆挡测电源线正负极,短路
是不是真的变压器坏了?
还有可能是保险丝旁电容、或电源开关处的压敏电阻吗?
估计变压器坏,直接找厂家是正路
rogerwewe 在 2005-6-11 12:05:42 发表的内容
借万用表测试:
是不是真的变压器坏了?
先查下保险丝旁电容、或电源开关处的压敏电阻是否有断路, 如没有就测环牛初级是否有短路, 如果没有就断开次级排线, 加电测各次级电压输出是否正常, 如果正常测4只整流2极管有否击穿短路, 如没有检查7812, 7912, LM317三端稳压是否有断路问题。
8888888888888888888888::::::顶8888888888888888888
........8888888888888888:8888:::::顶888888888888888888888
......88888888888888888::8888::::顶8888888888888888 8888
.....88888888888888888::8888::::顶:顶*88888888 88
....88888888888888888::888:::::顶::::::::::88888888 8
...88888888888888888::::88::::::顶:::::::::::::888888888
..8888888888888888888:::8::::::顶::aaa::::::::顶888888888
.888..8888888888::88::::8:::::顶:::::::::::::88888888888888
.88..88888888888:::8:::::::::顶::::::::::::88888888888888888
.8..8888888888888:::::::::::顶::\"@@@@@@@\"::::顶888888888888888
..88888888888:888::::::::::顶:::::\"@a@\":::::顶888888888888888888
.8888888888::::88:::::::::顶88:::::::::::::顶88888888888888888888
8888888888:::::8:::::::::顶88888:::::::::顶888888888888888888888888
888888888:::::8:::::::::顶8888888顶顶顶顶8888888888888888888888888888
888888.顶::::::::::::::顶8888888888::::::顶8888888888888888 8888888
8888...顶::::::::::::::顶88888888888::::::顶8888888888888888 888888
.888...顶:::::::::::::顶8888888888888:::::::顶888888888888888 8888
..888..顶::::::::::::顶8888:888888888888::::::顶8888888888888 8888
...88..顶::::::::::::8888:88888888888888888:::::顶顶888888888 8888
...88..顶::::::::::8888顶::88888::888888888888:::::顶顶88888 888
...8...顶::::::::::8888顶:::8888:::::888888888888:::::顶顶88 88
.......8顶:::::::8888顶:::::888:::::::88:::8888888:::::::顶顶 8
......88顶:::::::8888顶:::::::88::::::::8:::::888888::::::::顶顶
.....8888顶:::::888顶::::::::::8:::::::::::顶:::8888::::::::::::顶
....88888顶:::::88:顶::::::::::8:::::::::::顶:::8888::::::::::::::顶
...88 888顶:::::888顶:::::::::::::::::::::::顶:8888::::::::::::::::顶
...8 88888顶:::88::顶::::::::::::::::::::::::顶:88:::::::::::::::";:顶
.....88888顶:::88::顶:::::::::::::::::::::::::顶88::::::::::::;;::;:"顶
....888888顶:::88::顶:::::::::::::::::::::::::顶88::::::::::::::::::":顶
....888888顶顶::8::顶:::::::::::::88*::::::::顶8:::::::::::88*:::":顶
....88888..顶:::8::顶顶:::::::::::88@@88:::::::顶::::::::::::88@@88::::顶
....8888...顶顶::::::顶顶:::::::::88@@88:::::::顶顶::::::::::88@@88::::顶
....8888....顶:::::::顶顶:::::::::88*:::::::顶顶顶:::::::::88*:::::顶
.....888....顶顶:::::::顶顶顶::::::::::::::::顶顶::顶:::::::::::;;::::顶
......88.....顶::::::::顶顶顶顶:::::::::::顶顶顶:::顶顶::::::::;;:;::顶
.......88....顶顶:::::::::顶顶顶顶顶顶顶顶顶顶:::::::顶顶顶顶顶顶顶顶
........88....顶顶::::::::::::顶顶顶顶顶顶顶::::::::::::顶顶顶顶顶
.........88...8顶顶::::::::::::::::::::::::::::::::::::::::顶
..........8...88顶顶::::::::::::::::::::::顶:::顶::::::::::顶
..............888顶顶::::::::::::::::::顶顶::::::顶顶::::::顶
.............88888顶顶:::::::::::::::顶顶顶:::::::顶顶:::::顶
.............888888顶顶:::::::::::::顶顶顶:::::::::顶顶:::顶
............88888888顶顶:::::::::::顶顶顶:::::::::::顶:::顶
...........88.8888888.顶::::::::顶顶顶::::::::::::::顶::顶
...........8..888888..顶::::::顶顶:::::::::::::::::顶::顶
..............888888..顶:::::顶:::::::::::::::::::顶::顶顶
.............888888...顶::::顶:::::::::::::::::::::::::顶:顶
.............888888...顶::::顶::::::::::::::::::::::顶::顶
.............88888...顶:::::::::::::@:::::::::::::::顶::顶
............88888...顶:::::::::::::@@::::::::::::::::顶::顶
...........88888...顶::::::::::::::@::::::::::::::::::顶::顶
..........88888...顶:::::顶:::::::::::::::::::顶::::::::顶::顶
..........8888...顶:::::顶:::::::::::::::::::::::顶顶:::::::顶::顶
.........8888...顶:::::顶:::::::::::::::::::::::顶顶顶::::::::顶::顶
........888....顶:::::顶顶::::::::::::::::::::::顶顶顶:::::::::顶::顶
......8888....顶::::::顶顶:::::::::::::::::::::顶顶顶::::::::::顶::顶
.....888......顶:::::顶:::::::::::::::::::::::顶顶::::::::::::::顶:顶
..8888.......顶::::::::::::::::::::::::::::::顶::::::::::::::::::顶:顶
.............顶::::::::::::::::::::::::::::::::::::::::::::::::::顶:顶
............顶::::::::顶::::::::::::::::::::::::::::::::::::::::::顶:顶
............顶::::::::顶:::::::::::::::::顶:::::::::::::::::::::::顶:顶
...........顶::::::::::顶::::::::::::::顶::::::::::::::::::::::::顶:顶
...........顶:::::::::::顶88:::::::::顶::::::::::::::::::::::::顶:顶
...........顶::::::::::::8888888888顶::::::::::::::::::::::::顶:顶
...........顶:::::::::::::88888888顶:::::::::::::::::::::::::顶:顶
...........顶::::::::::::::888888顶::::::::::::::::::::::::::顶:顶
...........顶:::::::::::::::88888顶::::::::::::::::::::::::::顶:顶
...........顶:::::::::::::::::88顶::::::::::::::::::::::::::::顶顶
...........顶:::::::::::::::::::顶:::::::::::::::::::::::\":::顶顶
...........顶:::::::::::::::::::顶::::::::::::::::::::::::::顶顶
............顶:::::::::::::::::顶::::::::::::::::::::::::::顶顶
.............顶:::::::::::::::顶::::::::::::::::::::::::::顶
.............顶:::::::::::::::顶:::::::::::::::::::::::::顶
..............顶:::::::::::::顶:::::::::::::::::::::::::顶
..............顶:::::::::::::顶::::::::::::::::::::::::顶
...............顶:::::::::::顶::::::::::::::::::::::::顶
...............顶:::::::::::顶:::::::::::::::::::::::顶
................顶:::::::::顶:::::::::::::::::::::::顶
................顶:::::::::顶::::::::::::::::::::::顶
.................顶:::::::顶::::::::::::::::::::::顶
.................顶::::::顶::::::::::::::::::::::顶
..................顶::::顶::::::::::::::::::::::顶
..................顶:::顶::::::::::::::::::::::顶
...................顶:顶::::::::::::::::::::::顶
...................顶:顶:::::::::::::::::::::顶
....................顶顶::::::::::::::::::::顶
....................顶顶:::::::::::::::::::顶
....................顶顶::::::::::::::::::顶
....................顶顶:::::::::::::::::顶
....................顶顶:::::顶::::::::顶顶
....................顶顶::::顶顶:::::::顶顶
....................顶顶::::::顶顶:::::顶顶
.....................顶顶::::::::::::::顶顶
.....................顶顶::::顶:::::::::顶顶
......................顶顶::顶顶顶:::::::顶顶
......................顶顶::顶顶顶::::::顶顶
......................顶顶:::顶顶:::::::::顶
.......................顶顶::顶顶:::::::::顶
.......................顶顶::顶顶::::::::::顶
.......................顶顶:::顶::::::::::::顶
.......................顶顶:::::::::::::::::顶
.......................顶顶::::::::::::::::::顶
.......................顶顶:::::::::::::::::::顶
.......................顶顶::::::::::::::::::::顶
........................顶顶:::::::::::::::::::顶
........................顶顶::::::::::::::::::顶
.........................顶顶::::::::::::::;:顶
.........................顶顶::::::::::::::::顶
.........................顶顶:::::::::::::::顶
..........................顶顶::::::::::::::顶
..........................顶顶:::::::::::::顶
..........................顶顶::::::::::::顶
...........................顶顶:::::::::::顶
...........................顶顶::::::::::顶
............................顶顶::::::::顶
.............................顶顶:::::::顶
..............................顶顶::::::顶
............................顶:顶::::::::顶
............................顶:顶:::::::::顶
............................顶:顶::::::::::顶
............................顶:顶:::::::::::顶
............................顶:顶::::::::::::顶
............................顶:顶:::::::::::::顶
............................顶:顶::::::::::::::顶
............................顶顶:::::::::::::::顶
..............................顶顶:::::::::::::::顶
................................顶顶顶:::::::::顶顶
..................................顶顶::顶::::顶顶
...................................顶顶顶顶顶顶顶
......................................顶
谢谢楼上赐教!
